08-08-2014, 11:47 AM | #1 |
1939 Ford 4 Door Convertible
I am looking for the inside windshield trim for my 1939 Ford 4 Door convertible. I was told that the Woody trim would work. Any help appreciated.
Thanks Dick |
08-08-2014, 02:35 PM | #2 |
Re: 1939 Ford 4 Door Convertible
I think the woody, convertible coupe and convertible sedan are all thee same. G.M.
www.fordcollector.com |
08-08-2014, 02:41 PM | #3 |
G.M. is correct, they share the same cowl and windshield.
08-08-2014, 05:09 PM | #4 |
MEMBER EMERITUS
40-47 pick up ones can be modified to use also.
08-08-2014, 09:14 PM | #5 |
The 40-47 PU ones have an entirely different defroster louver. The 39 style that you need has a single and quite large defroster "louver" whereas the 40-47 PU is a longer 'slit' style. To convert the PU (or 40 sedan, same thing) you have to chop for height, change the corner radius's and relocate the counter-sink screw holes. It's a lot of work but it has been done. I have also built the center garnish from scratch, not too difficult. Good luck.
08-09-2014, 08:26 PM | #6 |
08-10-2014, 07:43 AM | #7 | |
If "all authentic' is not your highest priority, I suggest you at minimum check in to them. Original pieces in half way decent shape will cost you a lot more than $150 (each piece) IF you can even find them.
