Old 08-05-2014, 12:21 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 1939 Standard front fender braces
1939 Ford Standard front fenders.
Are there only one brace fitted per fender?
As looking Macs offer a short one and a longer one?
I have one one fitted per side at lower wheel arch aft of wheel.
Is this correct. They would be longer ones.
Thanks,
Phil
NZ
Phil Gillespie is offline   Reply With Quote
Old 08-05-2014, 09:00 AM   #2
39 STD
39 STD's Avatar
Default Re: 1939 Standard front fender braces
There are two braces per fender. The 'long' ones you have aft of the tire & the short ones that go between the inner fender and the front cross member behind the radiator.
Try to find original ones if you can because the aftermarket ones will work but don't fit quite right.
God is great, beer is good -----People are crazy
39 STD is offline   Reply With Quote
Old 08-05-2014, 01:17 PM   #3
Kube
Kube's Avatar
I agree. The repop short ones are total crap. Not even close to authentic. The longer ones (repop) will work but will take a lot of "fitting" to make them right.
Old 08-05-2014, 04:51 PM   #4
Phil Gillespie
Thanks very much for that info. Again assistance is much appreciated.
Phil
NZ
