Old 08-03-2014, 02:14 PM   #1
totalchefen
totalchefen's Avatar
Default Bad Noice ford truck 1940 1 1/2 ton 95hp
noise
went a long distance with the truck this weekend and then got a noise at the uphill, first in fourth gear, got the drop on the gas continue until the sound was dropping off the gas and then get change down to 3rd gear. voice sounded like two plates against one another
suggestions for troubleshooting?
totalchefen is offline   Reply With Quote
Old 08-03-2014, 05:48 PM   #2
Reds34
Default Re: Bad Noice ford truck 1940 1 1/2 ton 95hp
How are your levels? Ie: Oil, Transmission, Rear Axle. Could you tell where the noise was coming from? Do you have an oil pressure gauge? How were your temps?
Red
Reds34 is offline   Reply With Quote
Old 08-03-2014, 07:39 PM   #3
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Are you sure it's not spark knock, timing to far advance? Is the engine new or have a lot of miles? Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 08-05-2014, 11:04 AM   #4
totalchefen
Old engine
normal temp
oil check.
oil pressure normal
the noice will apears then the engine has to work hard running uphill
very difficult to located the noice.in front or under cabin
Old 08-05-2014, 05:36 PM   #5
41panelmark
41panelmark's Avatar
Originally Posted by totalchefen View Post
noise
Can you post a video with the noise?
41panelmark is offline   Reply With Quote
Old 08-05-2014, 05:40 PM   #6
alanwoodieman
could the noise be the parking brake band rubbing the drum? small spring is suppossed to hold it off but could need adjusting-reason you are hearing it at high speed could be when it is dragging enough to make the noise ,just a thought
alanwoodieman is offline   Reply With Quote
Old 08-05-2014, 05:44 PM   #7
ford3
noises or pinging on up hill pulls usually means a lean carb mixture, or timing advanced to much, a ping will sound like a sharp rattle, it happens on throttle opening on hills, more things will cause that noise, but those two are the main ones
ford3 is offline   Reply With Quote
Old 08-05-2014, 06:55 PM   #8
41ford1
41ford1's Avatar
Your description sounds like too much initial timing or a seized vacuum brake. My vote is a seized vacuum brake. The vacuum brake slows the timing under load. The vac brake assembly is on the other side of the distributor in the picture. For starters, remove the brake assembly and clean it. The large hex will remove it. Relubricate it with a light grease like Vaseline. If there is groove in the leather pad. Remove it from the piston. Turn it 90 degrees and reinstall it.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
