#1 |
Good Morning.
My A sadly had some bubbeling water (once hot) as well as little smoke out of bubbeling Water (not to be seen in the video) https://www.youtube.com/watch?v=47P5tPXwS84 As so, i took out the head to do a new gasket. 4 days of hard work (even lifting whole car with the engine lift). Worst thing i ever had to do on this car. Now i dont know about the head. Is that a head with 5.5 compression (as i suspect)? I did a lot of search but couldnt find pics (to compare). Is it recommended to use a "modern" gasket with silicone here? Thank you very much in advance. Christoph Last edited by Christoph; 08-03-2014 at 04:00 AM. |
#2 |
...and as i just want to learn....
what are those small holes for ???? ![]() |
#3 |
The holes are for water and steam. It is a higher than original compression head. Some of the venders recommend a model B head gasket for a "high compression" head. I have used both A and B gaskets. JB
#4 |
Thank you so far !
Sadly - No markings on the top of the head Will go into deeper investigation regarding small holes. Tried some air-pressure-testing and two of them seem to be blogged against the water-channels in the head. Will drill something inside to find out about.... Thank you |
#5 |
Can you post a picture of the top of the head.
#6 |
#7 |
It is you :-)
#8 |
Ha ha! Figures.. That isn't unusual...
#9 |
Looks. upside down to me also. Smiley face.
#10 |
Well
water pump is upside-dow. Which is good, as head is upside down too.... ![]() No sorry for trying to be funny. I agree - this pic appears strange. Find another pic from "the days of demounting" You might find the water-pump to be mounted correct . Head was "frozen" and refused my request so.... I started with a carpet-knife and cutting away all of the gasket. Then used a scraper (and hammered it in..) Then a sceond.... In this pic you find 7 of them ![]() Every mm of lifting the head was some task ![]() Its true - You have to find new words to get the head off Good thing : Head and engine did survive Will investigate regarding a good pic of the top of the head |
#11 | |
![]() Quote:
Could this be a higher comp/more modern head, as it looks maybe so ? BTW, congratulations on getting the head off without breaking it ![]() And, CHECK now that there may be gouges on head and block surface....reguiring resurfacing for positive sealing. Regarding your question as to using silly cone gasket. I'd use copper-coat, on both sides of new copper gasket. Also you can put a bit of copper coat around each cylinder and let it tack up before installing gasket. I usually put several head studs in loosely to guide gasket, as when it is tacky....you want the FIRST try to properly locate gasket to succeed. BTW..Pay attn. to what Pat says above, regarding sillycone type head gaskets. My experience matches his in this respect !! Last edited by hardtimes; 08-03-2014 at 01:19 PM. Reason: ................. |
#12 |
in reply to your answer on gaskets. Best Gasket Company makes a head gasket that has a strong black inner gasket covered in copper. These gaskets are earning a reputation for quality and durability. Your head probably requires a "B" gasket instead of one for an "A".
I am still seeing folks having trouble with the silicone gaskets although I have seen and used many with good results. Those require very frequent torquing for quite some time after installation. Additionally, the first run of the silicone gaskets had the red, water sealing strip misplaced through the center, driver's side, water port instead of around it. These are notorious for leaking. There are still some around being sold, so Caveat Emptor. If you buy one, get it from the source, which is Snyder's. Always set a new gasket on the head to check for fit before installing it. You will be amazed how many do not fit exactly right. |
#13 |
today we found
2 passages to be blocked. Im pretty sure, the left (which i called to be clogged) we managed to drill it to release the very strong plug inside... guess why the head-gasket collapsed. |
#14 |
Pat
I hold different new gaskets an im not sure which to use. Actually i dont like the looks of the ones with silicone. There is not enough silicone and it is VERY close to the passages (both - water and studs) I suppose, the silicone will slip into the passages rather than seal them. Next point: 3 of the studs are found to be repaired with heli-coil i guess the studs are not in correct direction and this is why its so hard to demount the head. ![]() is it possible to make passages somewhat wider to make mounting easier? |
#15 | |
![]() Quote:
Some guys have recommended slightly bending ![]() ![]() BTW..have you tried to CC the head to determine compression ratio ? |
#16 | |
![]() Quote:
Time-sert is probably the product. Helicoils can be trouble as they expand on the way out. The timeserts aren't a spring, and I've never had one come out anyway - even on a VW sparkplug, which are notoriuos for winding out helicoils and destroying the head.
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
#17 |
Thank you hardtimes
There was a silicone-gasket, but it was totally destroyed while demounting the head. luckily, the surfaces of block and head are still ok |
#18 |
found a better pic and i think the gasket was gone
arround the clogged water-passage |
#19 |
hardtimes
Thank you I really appreciate your ideas ! Snyders nowadays uses perma-coil but I guess its just another name for Heli-coil??? http://www.snydersantiqueauto.com/4978 I guess the heli-coil are still ok . I had to dremel one slightly as i found it to be higher than the Block (close to the stud - no issue) your asking for CC and i think you are talking about compression ? (sorry - not my fathers language ) prior to demounting: cold 5,5 4,6 4,9 4,8 hot 6,0 5,25 4,75 5,0 no 3 was hot somewhat lower than cold ! My all german calliper says: Studs are 11mm and holes are 12mm Did you ever try to “widen” the holes in the head ?? (To my opinion, the head has to go slick to the block.) I guess I will try to go to 12,2 or something. This evening I will compare the Silicone-headgasket to the head and will figure out if it still will be able to seal than… Thank you again Christoph |
#20 | |
![]() Quote:
![]() Bill W.
