Old 07-19-2014, 11:57 AM   #1
Terry,OH
Terry,OH's Avatar
Default Modifing speedometer turtle
I want to use a 17 tooth turtle gear. As the gears have lower number of teeth the diameter of the gear get slightly smaller. I want to use a 19 tooth turtle housing and cut the arc into the turtle deeper so the new gear meshes with the drive shaft gear properly. Any suggestions as what tools to use to modify the turtle housing?
Old 07-19-2014, 12:26 PM   #2
Charlie ny
Default Re: Modifing speedometer turtle
Terry,
Grab/fixture the turtle in your mill then set your boring bar to cut the desired radius to fit the torque tube diameter. If you can borrow a 17 turtle that would be
great to 'swipe' the critical dimensions. You will discover that depending on the 19t
turtle casting you use it is possible to run out of side wall....this happens rarely.
OR
If you have a 17t turtle to get the center line and other dims from send it
to me and I'll do it for the cost of shipping.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 07-19-2014, 02:36 PM   #3
Brian
Brian's Avatar
Once again an outstanding offer from one of Fordbarn's finest members. Full kudos to Charlie.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-20-2014, 05:39 AM   #4
Terry,OH
Terry,OH's Avatar
Wow: Thanks for the offer Charlie!
Old 07-20-2014, 05:48 AM   #5
BILL WZOREK
BILL WZOREK's Avatar
Charlie ny = #1
BILL WZOREK is offline   Reply With Quote
Old 07-20-2014, 08:42 AM   #6
bobgrice
I am getting ready to undertake this exact task. If anyone who reads this can provide the necessary dimension (center of gear shaft to center of arc, or the distance between bore OD's, if CTC is not available), I would greatly appreciate it! I have a handful of turtles, but no 17 to go by.
bobgrice is offline   Reply With Quote
Old 07-21-2014, 06:33 AM   #7
Terry,OH
Terry,OH's Avatar
Brattons sells the 17 tooth gear (Moly. embedded Nylon), the V8 shafts (square hole for cable) and the V8 end shaft retaining caps. They do not sell the housing. If you check the diameter of a 19 gear Vs the 17 you can determine the additional depth of cut necessary to modify a 19 housing. I have the gear on order but has not arrived.
Old 07-21-2014, 01:19 PM   #8
Digger
Digger's Avatar
This type of thing is what makes the Ford barn so great! I am just going through the same thing and boom! Here is the solution!! Very cool...
Digger is offline   Reply With Quote
Old 07-21-2014, 01:56 PM   #9
Tim Ayers
Originally Posted by BILL WZOREK View Post
Charlie ny = #1
Yes, he is. Charlie is the man!
Old 07-21-2014, 02:20 PM   #10
G.M.
I would suggest if you modify a turtle with another gear you file the 18 or what ever off and if possible stamp the 17 on the housing so the next guy knows what's going on. G.M.
www.fordcollector.com
Old 07-21-2014, 02:48 PM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
I believe we found out several years ago that the 17 tooth nylon gear from Bratton's Model A Parts will work in an 18 tooth, #18, 11-39, turtle housing, normally used with 3.54 gears, with no modifications necessary to the #18 housing.
John
Old 07-21-2014, 07:16 PM   #12
barnfind08
Terry why not call me for a n.o.s. #17 turtle assembly.
barnfind08 is offline   Reply With Quote
Old 09-04-2014, 08:33 PM   #13
Dan Hay
Dan Hay's Avatar
Bumping this thread with a question: Can an 18 tooth gear be used in a 19 housing without modification?
Dan Hay is offline   Reply With Quote
Old 09-05-2014, 07:25 AM   #14
Terry,OH
Terry,OH's Avatar
I have place a 18 gear in a 19 housing and it worked fine.
Old 09-05-2014, 09:19 AM   #15
JM 35 Sedan
Terry, what did you wind up doing to get a 17 tooth gear to work on your application/project?
John
Old 02-14-2015, 03:37 AM   #16
Fairlane500
Fairlane500's Avatar
I have used a 18 tooth gear in a 21 tooth housing and it worked ok also.
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
Old 02-14-2015, 08:23 AM   #17
Tim Ayers
Does anyone have a listing of which turtles go with which rear ratios?
Old 02-14-2015, 06:19 PM   #18
Lawrie
Lawrie's Avatar
Look in the green bible parts book,they list them
Lawrie
Lawrie is offline   Reply With Quote
