Old 07-15-2014, 05:42 PM   #1
grantsauder
grantsauder's Avatar
Default Horn rod/light switch
Have removed the steering and horn rod in my 31 CCPU. On reassembly, what are the positions for all the light switch, as referenced to a clock
Info much appreciated. Thanks Grant
grantsauder is offline   Reply With Quote
Old 07-15-2014, 06:21 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: Horn rod/light switch
It should be high beam 4 o'clock, low beam 5 o'clock, off at 6 o'clock and parking at 7 o'clock.
Old 07-15-2014, 06:45 PM   #3
mshmodela
mshmodela's Avatar
Interesting, I checked mine and I have low beams at 7 o'clock, off at 6 o'clock, and high beams at 4 o'clock...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-15-2014, 07:58 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Someone mixed up the wires at the headlight connections.
Old 07-15-2014, 07:58 PM   #5
Willie Krash
Willie Krash's Avatar
I'm with Mike.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 07-15-2014, 08:44 PM   #6
mshmodela
mshmodela's Avatar
Tom, thanks something to put on my list to correct.
-Mike
Cleveland, Ohio
Old 07-15-2014, 10:09 PM   #7
JOES31
JOES31's Avatar
This is the way I did mine.
JOES31 is offline   Reply With Quote
Old 07-16-2014, 04:49 AM   #8
hootchmonster
hootchmonster's Avatar
I just was able to switch wires around so I didn't have one bright headlight and one dim. Before I started I came here and found this post and also located nice wiring diagram. Thank you for everyone's help. Now the headlights run like they are supposed to.
1931 Murray S/W Town Sedan
Central Wisconsin Chapter MAFCA
hootchmonster is offline   Reply With Quote
Old 07-16-2014, 05:37 AM   #9
C26Pinelake
I agree totally with Mike. That is how mine is set up.
Wayne
C26Pinelake is offline   Reply With Quote
