07-11-2014, 09:23 AM | #1 |
F5 transmission
I have transnission out of an 1947 Ford F5 grain truck. I bought the engine and it came with the working trans. I've had this for over a year and I'm tired of moving it around the garage. Are the internals or case good for anything other than a large truck?
If any of you Barners need it, come get it! If you would like to trade ANYTHING for it ie: budweiser, air cleaner, valve stem cap or just a hand shake it yours!
Thank God this is only a hobby! |
07-11-2014, 03:06 PM | #2 |
Re: F5 transmission
Save the front, the bellhousing part... Some one will be grateful for it as it can be used to mount different trannys to an early(er) engine.
Karl |
07-11-2014, 03:15 PM | #3 |
Re: F5 transmission
The bellhouse part (call hogshead) go from $100 to $150 most of the time on ebay.
Edit: Not sure, but from the photo it looks like the bellhousing may not be a separate part but cast into the transmission housing. |
07-11-2014, 03:41 PM | #4 |
Re: F5 transmission
JSeery is correct, the bell housing is cast into the case making it a one piece. If no one can use it I will save the inspection cover and the screw down piece that holds the shifter in place. Of course I will completely dismantle it for education before scraping it. I will still attempt free to anyone who can use it for the next few weeks
07-11-2014, 03:54 PM | #5 |
Re: F5 transmission
I could use the inspection cover.
07-11-2014, 05:37 PM | #6 |
Re: F5 transmission
Red |
07-11-2014, 05:42 PM | #7 |
Re: F5 transmission
You're just a bit too far away for me.
Thanks anyway! |
