Old 07-10-2014, 08:36 AM   #1
fordtrk56
Default 1939 Ford PU head lite indicator
Any know how to remove the head lite indcator from behind the dash so I can replace the bulb?? I am also looking for a complete hood latch handle assembly..
fordtrk56 is offline   Reply With Quote
Old 07-10-2014, 02:29 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 1939 Ford PU head lite indicator
It just snaps in doesn't it?? Give it a little tug.
Old 07-10-2014, 03:05 PM   #3
TJ
TJ's Avatar
If it's like a '40 there is a small metal box on the back of the dash. That box holds the bulb and there is an elongated hole on one side that allows the box to slip over the high beam jewel. Move the box upward to disengage it from the jewel and pull outward to release it.
Old 07-10-2014, 03:52 PM   #4
V12Bill
V12Bill's Avatar
The bulb holder has a bar with a tapered slot in it.The small end of the taperlocks the jewel in place. The large end of the taper slips over the end of the jewel. The difficult part is trying to determine which end is the large and which end is the small. You have to slide the bulb holder in the correct direction to loosen it. Since the bulb holder is free to turn it could be any way.
V12Bill is offline   Reply With Quote
