Old 07-07-2014, 08:08 AM   #1
LopezCarguy
LopezCarguy's Avatar
Default restoring grooves on fender bead
I was hoping, wishing...wondering if anyone knew of tool/file that is made to restore the grooves on fenders??
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
Old 07-07-2014, 08:17 AM   #2
Growley bear
Default Re: restoring grooves on fender bead
A thread file might work if the pitch was right.
Chet
Growley bear is offline   Reply With Quote
Old 07-07-2014, 08:21 AM   #3
LopezCarguy
Chet; Thanks, I will give my thread chaser a look see...would be nice if it would do about a inch of grooves at once...Dick
Old 07-07-2014, 08:37 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Dick, a thread file is what most of us use to restore the fender serrations.
An inch long one would not be practical on two points, first there would be contact issues in various locations as some portions are straight and others are curved, and second, when you push a small ½-inch wide file, you realize how tough it can be, ...thus having one twice as wide would be twice as tough to push thru the stroke. Quite honestly, you will find this task goes quite quickly and in less than an hour you will be finished.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-07-2014, 10:00 AM   #5
d.j. moordigian
d.j. moordigian's Avatar
Brent.......lol....how about "squaring" that...
d.j. moordigian is offline   Reply With Quote
Old 07-07-2014, 07:32 PM   #6
Bill in NJ
How many threads per inch ?
Bill in NJ is offline   Reply With Quote
Old 07-07-2014, 08:11 PM   #7
Cape Codder
Cape Codder's Avatar
Although very interested when someone talks about fenders on this forum I must ask, what grooves are you guys talking about?
Cape Codder is offline   Reply With Quote
Old 07-07-2014, 08:28 PM   #8
wrndln
What they are referring to are the serrations on the bottom of the bead on the outside edge of the front and rear fenders. Just move your fingers along the bottom of the bead and you can feel the small cuts. I believe they were made when the wire was "rolled" into the bead.
Rusty Nelson
wrndln is online now   Reply With Quote
Old 07-07-2014, 08:33 PM   #9
ford3
the groves on the side of the fender opening, where the metal is folded over to keep the stiff support wire in place,
ford3 is offline   Reply With Quote
Old 07-07-2014, 09:40 PM   #10
Gary WA
Gary WA's Avatar
Going for points hey!!! Hi Dick.
www.whidbeymodelaclub.com
Old 07-07-2014, 11:29 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Vermin's fenders are shiny BLACK & still has the grooves, that fill up with white wax residue. "Maybe" they're NOS fenders??? Some guys prime their fenders HEAVILY, so they don't show. To each his own, sounds like a song title. I like, "TAKE THIS JOB & SHOVE IT", better!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-08-2014, 05:47 AM   #12
Kevin in NJ
Like Brent says, it goes quick.
The thread file will try to keep to the old grooves so you just have to overlap the grooves. The grooves can get lost quick under paint so make them deep and keep the coats of paint down.
Kevin in NJ is offline   Reply With Quote
Old 07-08-2014, 07:59 AM   #13
Bill Underwood
Not at the shop to look at TPI; I think 18.
But to confirm, mark off an inch and count them.
Bill Underwood is offline   Reply With Quote
Old 07-08-2014, 09:10 AM   #14
Cape Codder
wrndln - Thanks for the explanation about the grooves on the fenders!
Old 07-08-2014, 06:54 PM   #15
Bill in NJ
It looks like 20 to me, but I could be wrong.
Old 07-08-2014, 07:42 PM   #16
Terry,NJ
Terry,NJ's Avatar
Put a 5/16 - 18 bolt next to them and see how they line up.
Terry
Terry,NJ is offline   Reply With Quote
Old 07-08-2014, 08:17 PM   #17
31 RPU
Take a piece of paper and put over the grooves and take a small dowel rod or pencil and rub across the threads to make an indentation of the grooves in the paper and then measure them. Better than standing on your head...lol
31 RPU is offline   Reply With Quote
Old 07-08-2014, 08:22 PM   #18
d.j. moordigian
I'm sure a bunch of you have a "thread gauge" that came with your
tap and die set....that would be the ideal tool to use before picking
up a thread file. Personally, I haven't checked a fender yet....they
could be metric....
Old 07-10-2014, 08:40 AM   #19
LopezCarguy
Thanks guys, I now have four...four corner files with different thread pitches..will now restore grooves....so all who run fingers under fenders to see if they are original will find grooves...they are original but during restoration you loose some grooves when welding up cracks....
Old 07-10-2014, 09:13 AM   #20
1wonton
Is this serious? Who on earth would file the little serations in the fender bead, and WHY?
1wonton is offline   Reply With Quote
