#1 |
Has anybody tried this combination ? I'm trying to get a little safety zone in before the coolant boils. The coolant requires an additional push over water
36fordguy |
#2 |
What about adding some anti freeze/summer coolant?
I asume the rad is properly clean? and the block properly clean? Where abouts are you located? Martin. |
#3 |
Loc Carson City Nv . A combination altitude and temperature keeps me near boiling ( about 190 to 200) . It has a Griffin Rad in my 36 PU I'm only running a 4# cap not sure how High I can go in pressure before I have any problems. Last year it boiled on 100 plus day after getting in stop and go traffic mainly when you stop and the heat soak sends the temp up. This year I would like to correct this and be able to go to lake tahoe at noon time (2000 ft climb in about 10 mi)
#4 |
In my 36 I had a built 59AB and used Fryer pumps(have bronze impellers and sealed bearings)Walker radiator w/7lb cap .I also had Evans cool.Never ever had any cooling issues.I have an extra unopened gallon of Evans cool for free if you pay the shipping.
#5 |
I'm sure your Griffin will handle 7lbs no problem. As water is proven to have better cooling qualities than antifreeze, you would benefit from plain water plus corrosion inhibitor, combined with a 7lb cap will probably fix it. Sorry, I have no idea whether the Evans coolant is any good.
#6 |
I'm not questioning your knowledge here, just I thunk that anti freeze raised the boiling point of water, and in doing so would take some stress off the cooling system. Martin. |
#7 | |
![]() Quote:
![]() The instructions on the bottle say, "Using less than 50% anti-freeze will improve temperature reduction." But, the instructions on another brand of coolant says to never run with water alone without some anti-freeze. So, it's true. Water is a better thermal conductor than anti-freeze. The "raising of the boiling point" of water by anti-freeze only makes a difference in a non-pressured system, not a pressurized system where the pressure keeps the water from boiling, not the anti-freeze. So, because I drive my car all year 'round from minus zero temperatures in the winter to 100+ temperatures in the summer, I put just enough anti-freeze to protect down to the expected winter low (about a gallon), with a couple of bottles of hy-per lube, which increases the cooling ability of the water over 50-50 mix in the heat of the summer.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 07-02-2014 at 02:38 AM. |
#8 |
You should know that Skip does not recommend his pumps to be used with thermostats. Their impeller is a "multi-flow" design that will increase water flow only without the resistance of a thermostat. To move water through a thermostat one needs the extra pressure created by a centrifugal impeller as the stock and all modern replacements (except Skips) are. So, the only way to move more water with Skip's pumps is to run them without thermostats. (Won't any pump move more water without thermostats?) There are plenty of very good reasons not to run an engine without thermostats. So, put 2 and 2 together and there you have it.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#9 | |
![]() Quote:
www.fordcollector.com |
#10 | |
Yes I would support what Bassman says also. We had a mustang as a track car and with 33% anti freeze at around 3 laps it would overheat. So on a cooling system reps recommendation we filled it with water and water wetter and had a great response and problem solved. So in ou flatheads now we only run water and water wetter. The cooling system rep had the theory that antifreeze did not transfer the heat as well and left air pockets and hot spots but did lower boiling point so was a catch 22.
#11 | |
![]() Quote:
#12 |
Thanks for replies guys.
To 36fordguy, it seems a water wetter of some kind may help. There is experience in the answers above. Specially the roundy roundy mustang, kept that from boiling over in real back to back laps. As for Evans coolant. Is that the waterless one? No body got experience of that? Personally I like something with water, you can top it up at any tap (faucet) with no problem. The waterless ones, I believe you can't put water in with it? That could leave you stranded in Moose But Montana. Have a word with Skip, see what he thinks, he is the man who made the pumps. I'd try upping the cap pressure first. Could be a cheap fix. What do Griffin recommend for pressure? Martin |
#13 |
There is definitely a balance that must be struck between maximizing cooling in the summer and preventing freezing in the winter. If freezing was never a risk then plain water without antifreeze but a good anti-corrosive, pump lubricant, and water wetter may well be the best solution, in the short run. In the worst case scenario one could switch twice a year between that and water with anti-freeze for the winter. I used to do that but got tired of it and decided that whatever I added to plain water that was not antifreeze for the summer ruined my water pumps so now run minimal antifreeze all year round. As I said before, one of the water wetter manufacturers said to never run on water alone without any antifreeze.
#14 | |
![]() Quote:
#15 |
At first glance that may seem to be logical, but, in actual practice, it doesn't work that way. The faster the water moves the better it cools.
