Old 06-28-2014, 10:36 PM   #1
hotrodalley
hotrodalley's Avatar
Default Master Cylinder Mount
I am currently in the process of converting another model a to hydraulic brakes.
This conversion will be using a '39 transmission with Cling's Adapter. Any ideas of where to mount the master cylinder without an unnecessary modifications would be much appreciated.
hotrodalley is offline   Reply With Quote
Old 06-28-2014, 10:59 PM   #2
KenCoupe
KenCoupe's Avatar
Default Re: Master Cylinder Mount
Cling's makes and adapter for the 32 - 39 transmission. You should call Cling's and see what they recommend. They have always been very helpful when I talked to them.
KenCoupe is offline   Reply With Quote
Old 06-29-2014, 12:53 AM   #3
CarlG
CarlG's Avatar
Here's a solution on eBay:
http://www.ebay.com/itm/FORD-MODEL-A...66#ht_54wt_922
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-29-2014, 06:11 AM   #4
john in illinois
john in illinois's Avatar
The battery box Carl posted is what I have used on my Tudor for several years. Clings mount uses a single circuit master cyl. I like having separate front and rear circuits.
John
john in illinois is offline   Reply With Quote
Old 06-29-2014, 07:32 AM   #5
Terry,NJ
Terry,NJ's Avatar
Go through my pics under "My 30 TS" and 'My coupe" in my profile. Both cars have Hyd Brakes. The TS is a welded plate that I did NOT weld to the frame, it was a previous owner. In my coupe, there was a forties Ford single outlet cylinder that I replaced with a Dual Cyl. This required making a new plate, but I used all the old mountings. It mounts on the flange of the cross member. I put a angle iron stiffener between between the cyl and the cross member to prevent flexing of the flange.
Terry
Terry,NJ is offline   Reply With Quote
Old 06-29-2014, 08:00 AM   #6
denis4x4
denis4x4's Avatar
This is a clean way to mount a MC without drilling any holes and uses the stock brake cross lever. Only need to weld an arm on the cross lever. I even used a cut down A brake rod to actuate the MC. Quick, easy and cheap. Have to give credit to Bert's Model A for this idea.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
