Old 06-24-2014, 03:23 PM   #1
bluesman31
bluesman31's Avatar
Default Verifying charging system on 6V Alternator system
Just got my new 36 Pickup going and it appears to have been restored bone stock with the exception of a 6V pos ground alternator.
I am charging the battery since it seems to be really low. I would like to do a quick check of the charging system to see if she is functioning correctly.
Before I charged the battery I was still be able to barely (turn over slow) start the car, and then the stock ammeter would read a hair below 0 when running lights off, and dips to neg 5 or 10 with lights on. Is this what I should expect? I thought with the alternator it should maintain near zero with the light on? My assumption is that the alternator has a voltage regulator, but not sure? I think it's a one wire setup
31 Deluxe Roadster
bluesman31 is offline   Reply With Quote
