Old 06-23-2014, 02:43 PM   #1
j.threadgill
j.threadgill's Avatar
Default 1938 Ford 4 Door Convertible
I am trying to fix an issue with Headlights and taillights not working. I do not see a switch for the headlights. It has a switch that turn on the fog Lamps, which work. There is a small two position toggle switch on the bottom of the dash on the left side of the steering column which doesn't seem to do anything. Also has a floor switch which looks like a dimmer switch. Any good sites to go to with diagrams and the like and any suggestions. Also is there more than one fuse bar location? Everything I have found says there is only one under the dash on 1938 Ford.
j.threadgill is offline   Reply With Quote
Old 06-23-2014, 02:49 PM   #2
39topless
Default Re: 1938 Ford 4 Door Convertible
Switch is on your horn button. Rotate cw for on ccw for off.
39topless is offline   Reply With Quote
Old 06-23-2014, 02:53 PM   #3
j.threadgill
Thanks for the quick response, I will check that after work.
Old 06-23-2014, 07:55 PM   #4
Fe26
The two position Toggle switch is for the dash lights.
Fe26 is offline   Reply With Quote
Old 06-24-2014, 12:23 PM   #5
j.threadgill
Thanks 39topless for the info. I would have never thought to check for switch/horn button. Lights work just fine.
and Thanks FE26 for that info.
