Old 06-22-2014, 07:22 PM   #1
1930artdeco
1930artdeco's Avatar
Default dist part testing
Hi Folks,
Just curious about testing some things. I am building up an original dist and would like to test a few things just to make sure they are good.
1-Lower plate with original wire. I did a continuity test and my meter beeped. I assume the wire is good to use.
2-Is there a way to test original style condensers with a meter? One was in the body-I assume it is from the 60's or earlier. Mind you I am an electrical dummy so if you post instructions follow the KIS principle.
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
