Old 06-19-2014, 07:22 PM   #1
Ben Umberger
Default Tillotson
I would like to ask a few Tillotson Crab questions:
What do I clean with
What do I NOT clean with
What do you use for a Plug after having drilled out old ones
I assume that drilling is the way to get the old ones out
Can the Venturi come out or is it a fixed part of the carb
I知 working on one for a fellow, the top of the Ventura has a ス chip out of the top. It used to run well I知 told, I assume hat it already had the chip as I didn稚 see any such broken parts, how bad is this problem?
The body is warped a bit, I知 understand you can bake it with a hose clamp around it to bring is together, What Temp, and how long would you recommend.
Any other advise?
I took easily 2 table spoons worth of caked dust out of this thing.
Pictures of this carb can be seen at: https://www.dropbox.com/sh/j2ayegvik...ytpVUdfBGUoULa
Thank you very much
Ben
Ben Umberger is offline   Reply With Quote
