Old 06-19-2014, 01:54 PM   #1
MurphyJ
Default Coil question
I have a stock 6 volt ignition system. Replacing the coil?
Can i use either a 6 volt or 12 volt coil, or do i need to go 6 volt only??
Thanks for your advise and wisdom, always most helpful and sometimes very funny!
MurphyJ is offline   Reply With Quote
Old 06-19-2014, 02:16 PM   #2
tbirdtbird
Default Re: Coil question
you need a 6V coil on a 6V system.
A 12V coil has an internal resistor imposed on 6V windings, and thus your primary resistance will be too high
why not get a 6V coil directly from FSI ignitions? they are one of the few sources left of American made 6V coils
'31 180A
tbirdtbird is offline   Reply With Quote
Old 06-19-2014, 07:46 PM   #3
glenn in camino
glenn in camino's Avatar
6 volt coils are available from any Model A parts supplier.
glenn in camino is offline   Reply With Quote
Old 06-19-2014, 10:05 PM   #4
tbirdtbird
yep and u will prolly get an offshore coil.
notice i said American made
unless u don't care
'31 180A
Old 06-19-2014, 10:17 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
My first choice for a coil would be a good original coil, which Bert's in Denver would most likely stock.
Bert's 800-321-1931
Old 06-19-2014, 10:31 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Any 12v coil that uses an external resistor will work.
Old 06-20-2014, 07:18 AM   #7
29 Tudor
29 Tudor's Avatar
NAPA will (probably) have a coil and I (and others I know) have had VERY good performance from their coils.
sd
29 Tudor is offline   Reply With Quote
