Old 06-11-2014, 06:19 PM   #1
Nlbloch
Default starter problem
My starter will occasionally "stick" in the on position -- that is, it continues to whirr after the floor button is depressed, even after the engine has started. I haven't figured out how to "unstick" it; generally, it stops on its own but sometimes making a large popping noise. I suspect the continued running is not good for the starter.
What could be the problem, and more importantly, the solution?
Nlbloch is offline   Reply With Quote
Old 06-11-2014, 06:23 PM   #2
newshirt
newshirt's Avatar
Default Re: starter problem
The copper switch could be sticking to the starter button. Maybe need a replacement switch?
http://parts.modelastore.com/show_Product.asp?ID=4117
Ray White
newshirt is offline   Reply With Quote
Old 06-11-2014, 07:10 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
You need to determine if the problem is the push rod to switch misalignment causing binding, or if you have a weak contact strap inside the switch.
Old 06-11-2014, 07:39 PM   #4
darrylkmc
darrylkmc's Avatar
Nlbloch,
Sometimes you will find, after removing the switch, is that either the starter stud and/or nut are not solid copper. I have seen copper coated steel, and if that is the case the switch strap will weld itself to the steel once the copper coating has warn away.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 06-23-2014, 10:09 AM   #5
Nlbloch
The starter button (the penny sized circle on the starter motor) has a pit or mark on it as if it received an electric shock. Could this indicate, or be the source of, the problem?
I have ordered a new starter switch but not yet installed.
Old 06-23-2014, 10:23 AM   #6
newshirt
newshirt's Avatar
Post a photo. The copper strap could have been temporarily welded to this pit on the button because of a dirty connection. Bad connections cause heat. Heat welds soft metals together.
Ray White
Old 06-23-2014, 02:54 PM   #7
Will N
Will N's Avatar
Happens to me occasionally too. I've tried putting a small section of rigid plastic tubing between the copper strap and starter body to act as a spring to help push the copper strap back up, but is still sometimes welds itself to the contact. I believe that the original starter switch had a bronze strap, not copper. The bronze is stiffer and would naturally spring back better than the copper used in the repro switches. I've also found that the welding usually occurs when my battery doesn't have a full head of steam- like when it's been in the garage for a week, unused. I've been using the battery tenders to keep the charge topped off, and the frequecy of the welding is much less.
By the way- it's not good for the starter to run on like that. Even though it doesn't have the normal load of the engine that would cause it to overheat in no time, spinning free and fast for an extended period will cause the bushings to wear, and it will overheat the motor after a while. A battery quick disconnect is useful to cut power to the starter.
Will N is offline   Reply With Quote
