Old 06-09-2014, 08:58 AM   #1
usered
usered's Avatar
Default Windshield - what is it?
Several months I posted a question as to what this roadster windshield I got with a '30 roadster I purchased is. Thought I might try again and find out what it fits, if its not a model A.
Its the same size as a standard windshield 15 1/4" height and 42 3/4 long.
The curve at the bottom is the same as a model A. The outside diameter is 1" which I think is larger then the original. The "L" brackets at the corners are clearly home made.
I polished it out and as you can see it is in great condition. Is it a model A, if not what might it be for, maybe someone could use it.
usered is offline   Reply With Quote
