Old 06-08-2014, 10:33 PM   #1
vintageautospirits
vintageautospirits's Avatar
Default 30-31 Cowl Lights Need Help !
I bought a pair of used cowl lights that seem to have mixed internal parts. Ordered the bulb holders that came with a rivet but there is nothing to rivet them to. I can't find one single diagram or exploded view parts image for these.
Any help would be appreciated ..
vintageautospirits is offline   Reply With Quote
Old 06-08-2014, 11:00 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: 30-31 Cowl Lights Need Help !
See that hole at the base of the reflector? That's the hole for the rivet'
Old 06-08-2014, 11:02 PM   #3
jw hash
jw hash's Avatar
what you have is an early 30 cowl light and I do not think anyone make parts for them. it looks like you have all the correct parts in the picture with the exception of the yoke that holds it all together has part of if broken off. the socket that you purchased is for the later 30-31
jw hash is offline   Reply With Quote
Old 06-09-2014, 12:47 AM   #4
vintageautospirits
the bulb holder is too large to fit through the reflector I can't seem to find any of the internal hardware on the parts suppliers website, or even a picture on the internet of one apart, everything I have is what you see
Old 06-09-2014, 12:52 AM   #5
Mike V. Florida
Call Berts on Tuesday (they are closed Mondays)
Old 06-09-2014, 01:02 AM   #6
vintageautospirits
will do, thanks
Old 06-09-2014, 01:41 AM   #7
mot
Registered User
mot's Avatar
john hash is correct
its an early 30 cowl light
very different than a later one
it has a screw ,not a rivet
mot is offline   Reply With Quote
Old 06-09-2014, 06:49 PM   #8
KGBnut
KGBnut's Avatar
My cowl lights are also mixed up, one like this one, and the other the more common type. The one like this was missing the part that makes the electrical contact at the center-back of the bulb. I ended up making a temporary part with an old credit card.
That was four years ago. My temporary fixed is still going strong.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 06-09-2014, 06:53 PM   #9
vintageautospirits
Yes the car is an early 30 with the 29 instrument panel, so that makes sense. I will probably have to build them as hybrids.
Old 06-09-2014, 10:24 PM   #10
mot
Registered User
mot's Avatar
here is what the difference is
the early 30 lamps are completly different than the later ones
the bulb mount is different
the lens is different
the rim is different
the reflector is different
the early one takes a screw through the inner mounting bracket ,which holds the reflector
the riveted one just rivets the bulb holder
and the reflector slips over the holder
the early 30 rim has no hole in it to secure the rim,it just snaps in place
the later one has a hole and screw to hold it to the shell
the early lens has Top on the top of the lens
so as you can see they are totally different in every way
the arms although different are interchangeable
tom
