Old 05-31-2014, 11:26 PM   #1
mrtexas
mrtexas's Avatar
Default 49 steering wheel
Can someone tell me if this is a 49 steering wheel? Also what year did the automatic gear indicator come from?
mrtexas is offline   Reply With Quote
Old 06-01-2014, 07:28 AM   #2
George49Ford
George49Ford's Avatar
Default Re: 49 steering wheel
Appears identical to my '49 steering. About the automatic indicator, sorry - no idea on that one.
George49Ford is offline   Reply With Quote
Old 06-01-2014, 08:19 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Looks like a '51 column that was used to accommodate the later automatic that sits behind the non-flathead OHV engine.
Old 06-01-2014, 08:31 AM   #4
green50
green50's Avatar
I agree, that is a '49 wheel. The Ford-O-Matic came out in '51. It appears that someone put an automatic in your '49 along with the steering column. If you have a space between the wheel and column it may be corrected with using a '51 wheel, not real sure though.
Gene
green50 is offline   Reply With Quote
