Old 05-30-2014, 03:49 PM   #1
marty in Ohio
marty in Ohio's Avatar
Default Fuse protection??
For the past three days I have been chasing an electrical problem in the "A". It started with the horn and that was corrected, but I think there is a problem with the safety fuse on the starter. This was probably the first safety item I installed on the car twenty years ago. At first I pulled the fuse each time I parked the car and this eventually broke the fuse holder, so I bought another. I don't have a disconnect switch (kill switch) as I feel that it will only protect the wiring when the car is off.
What is the opinion of you Ford Barners, fuse or switch??
marty in Ohio is offline   Reply With Quote
