05-19-2014, 08:11 AM | #1 |
'50 Spark Plug wire bracket
Has anyone had problems with spark jump using the stock 7RA/8BA- 12111 brackets on the '49-'50? I was putting together a list of grommets etc. and planned to replace the grommets (12297), but wondered if it would be better to use the '51 style (OBA-1211) to keep the wires separated better. I will be using Moroso 910-64200 wires as recommended by Bubba in a past thread.
Anyone found an after market organizer that does the job better? |
05-20-2014, 11:30 AM | #2 |
Re: '50 Spark Plug wire bracket
Here's an idea you might want to try. Modify the stock wire looms by cutting them and brazing on flat washers to orient the way you want your spark plug wires to go. Then use slotted rubber washers in the washer holes as insulators. The wires shown are on an 8BA. The wire dia. is 8mm. The first 2 pictures are of the driver side. Pictures 3 and 4 are of the pass. side. Little plastic wire separators used as needed.
05-20-2014, 01:07 PM | #3 |
Howard |
