Go Back   The Ford Barn > The Archives > Early V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Re: Flathead Lifter Adjustment
Can anyone from the weekend crew tell me how to adjust the lifers? Thanks.
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
are you sure thry're ARDUN heads?
Old 03-25-2005, 04:00 AM   #3
Guest
Posts: n/a
Default Flathead Lifter Adjustment
Need help for a friend with a Flatead which he is installing a set of Ardun Heads...how do you adjust the lifters in these things without them turning? There must be a special tool of somekind?! Anyone got a pic/tell me where to get it from?! Thanks.
Old 03-25-2005, 04:28 AM   #4
Guest
Posts: n/a
There are special wrenches that don't work very well. If the heads are off I find it easier to pull the whole valve assembly, adjust the lifter on the bench, and reassemble.
Old 03-25-2005, 05:13 AM   #5
Guest
Posts: n/a
Ardun heads have adjustable rocker arms.
Old 03-25-2005, 10:14 AM   #6
Guest
Posts: n/a
ardun heads are o/h valve conversions for the flathead ford engine
