Old 05-12-2014, 04:58 PM   #1
marty in Ohio
marty in Ohio's Avatar
Default Ear Piercing Squeal
Hey, Barners,
Worked on a '30 coupe today. We changed the carb. and started it up to take a test drive. When it started there was a squeal that shook the whole garage and those of us in it. The engine was rebuilt last December and it seemed O.K. until today. We questioned where the noise was coming from so I took off the belt to rule out the water pump and generator. Still had the squeal! It sounds like it's coming from the front of the block. We then turned it over with the crank and it sounds like a "chirp" with every half revolution. The engine was rebuilt by Duane Roach in Mt. Gilead, Ohio who recently retired and sold his business. Duane always did excellent work and now we don't know where to turn.
Any ideas on the squeal?
marty in Ohio is offline   Reply With Quote
Old 05-12-2014, 05:14 PM   #2
Randy in Illinois
Randy in Illinois's Avatar
Default Re: Ear Piercing Squeal
If you didnt have the noise before, you should have it now. Check for a vacuum leak at the carb base . Badgasket? Warped carb base, or manifold surface. Check manifold to block for vacuum leakes. Vacuum wiper conections. Use a spray bottle with water. Nothing flameabile !!!! The noise will change or go away. Good luck
Randy in Illinois is offline   Reply With Quote
Old 05-12-2014, 05:47 PM   #3
Smog Tech
Smog Tech's Avatar
Sounds like front seal. Try any penetrating oil and see of the squeak stops. For a more permanent fix I use motorcycle chain lube.
Smog Tech is offline   Reply With Quote
Old 05-12-2014, 05:49 PM   #4
Tom Endy
Tom Endy's Avatar
Did you oil the distributor bushings?
Tom Endy
Tom Endy is offline   Reply With Quote
Old 05-12-2014, 06:09 PM   #5
Brentwood Bob
pilot bearing. Bob
Brentwood Bob is offline   Reply With Quote
Old 05-12-2014, 06:16 PM   #6
springerpete
springerpete's Avatar
Had the same issue with a friends newly rebuilt motor. Squeal came from the timing gear area as there was no lubrication. Motor had sat after the rebuild and all the lube was gone.
springerpete is offline   Reply With Quote
Old 05-12-2014, 06:58 PM   #7
ford3
my guess is the carb or carb gasket simply because every thing was all right till the carb was changed, the chirp every half rev is one piston sucking air on the intake stroke
ford3 is offline   Reply With Quote
Old 05-12-2014, 07:08 PM   #8
super flat
super flat's Avatar
That is my bet also and it is easy to spray that front seal too.
I am usually relatively happy------Gary
super flat is offline   Reply With Quote
Old 05-12-2014, 07:26 PM   #9
1crosscut
1crosscut's Avatar
Marty it is not clear to me in your post if this is the first time that the engine was started after the rebuild or it has been running okay and just started making the noise after the carb work.
If it is the first start I would say that the spring between the timing cover and cam shaft has no lubrication. Pull the cover and lube it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-12-2014, 08:19 PM   #10
midgetracer
midgetracer's Avatar
I second 1Crosscut. It sounds like the cam plunger was not lubed when put together. It makes a serious scream.
midgetracer is offline   Reply With Quote
Old 05-12-2014, 08:31 PM   #11
James Rogers
James Rogers's Avatar
Retorque the head nuts. You have some that are loose and the compression is leaking. It will make a very high pitched squeel.
Old 05-12-2014, 08:39 PM   #12
ford3
the simple thing to do is put another carb on engine and see if that stops the squeal
Old 05-12-2014, 10:42 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Pulley could be hitting.
Old 05-13-2014, 12:37 AM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
That was my first thought also because I had it happen on an engine I installed for a customer. I did several short runs trying to figure out what it was. I removed the side cover and saw there was a flood of oil going onto the timing gear, so I figured the pluger should get oiled in no time. Actually it took several short engine runs before the squeal quit. It was probably close to 3 hours total of run time before the noise was gone for good. Until then the noise would come and go at times.
Oil the flat spring on the front motor mount, in case it's dry and squeaking.
Old 05-13-2014, 07:56 AM   #15
marty in Ohio
Thanks for all the suggestions. We'll try to pinpoint the problem. In answer to Dave's (1 crosscut) question - this is a recently rebuilt engine, but it has been run and has probably 100 or so miles on it. Lots of rain and flooding in northern Ohio today so we may have to wait a couple days before we can get to the car.
Thanks again for all your answers
Marty
Old 05-13-2014, 06:02 PM   #16
marty in Ohio
Well, you guys have come through again!! The squeal was actually a bad gasket between the carb. and the intake manifold just like ford3 said. We started the engine this afternoon and it screamed like a banshee. I put my hands around the carb. and released them a couple times and the noise changed. We put on another gasket and the noise was gone. We left the Tillotson on and will rebuild the Zenith.
I can't say enough about the help I have gotten from Ford Barn. It's like you guys are looking over my shoulder telling me what to try next.
Thanks again for the help.
Marty
Old 05-13-2014, 06:27 PM   #17
Tom Wesenberg
I like to use the thick copper gasket for the carb. It's much less likely to leak than the thin gasket.
Old 05-13-2014, 06:32 PM   #18
C26Pinelake
I had the squeal you speak of. It was indeed the carburetor gasket that had recently been installed. I did as Tom suggests and put in the thick copper gasket and problem was fixed immediately. Hope yours is that simple.
Wayne
C26Pinelake is offline   Reply With Quote
Old 05-14-2014, 01:46 AM   #19
CarlG
CarlG's Avatar
Ear Piercing Squeal = the sound my 4 year old daughter made 5 seconds after she had both ears pierced at the same exact instant. Both were done at the same time -- we knew that if they weren't, only one would ever get done!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-15-2014, 03:15 PM   #20
ford3
Marty in Ohio, altho its nice to know I was right on the carb gasket, but it was Randy in Ohio who correctly identified the problem first, I just seconded his opinion
