Old 05-11-2014, 02:32 AM   #1
jojofilo88
jojofilo88's Avatar
Default Ring and Pinion Removal
Hey guys,
Any alternate methods to getting the pinion off? I'm replacing both ring and pinion and can't get it off! The whole drive shaft keeps spinning when I try removing the but with a pipe wrench!
From what I've read you can try pulling the whole deal off or you can unbolt the two nuts on the shart over the pinion. I don't have wrenches that big (2+") so I'm really struggling, although I do have a 2/3 pronged puller.
I'm planning on going to find wrenches I'm the morning but thought I'd check for more ideas from you fine folks.
Thanks!
Joe
jojofilo88 is offline   Reply With Quote
Old 05-11-2014, 04:43 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Ring and Pinion Removal
I made my own wrenches from some 3/8" plate steel, but the Model A parts houses sell them. I've seen a hammer and chisel used a few times, but hate to see stuff like that done.
Old 05-11-2014, 05:49 AM   #3
Floats
Floats's Avatar
Hi Tom,
Could you pse give us the sizes of the wrenches required as I have a gear change coming up, I d like to get prepared and make my own.
Regards
Chris
Cape Town
Floats is offline   Reply With Quote
Old 05-11-2014, 06:32 AM   #4
tbirdtbird
slow down and get the correct wrenches from the suppliers.
It made it 80 yrs so far without being chewed up.....
pipe wrenches are for plumbing....
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-11-2014, 06:58 AM   #5
Tom Wesenberg
According to the Parts Price List, the nut is 2 1/8".
I cut the steel plate with a plasma cutter at a high school shop, then used a sanding belt, disc sander, files, and grinders to finish the wrenches.
Old 05-11-2014, 08:17 AM   #6
Ice man
Ice man's Avatar
Pipe wrenches???????????
Ice man is offline   Reply With Quote
Old 05-11-2014, 08:33 AM   #7
Floats
Floats's Avatar
Tks Tom,
Chris
Old 05-11-2014, 10:55 AM   #8
mrtexas
mrtexas's Avatar
Originally Posted by jojofilo88 View Post
Hey guys,
Thanks!
Joe
I used one purchased special wrench and one large cresent wrench from harbor freight.
mrtexas is offline   Reply With Quote
Old 05-11-2014, 11:54 AM   #9
Mikeinnj
Mikeinnj's Avatar
You will want to read this article by Tom Endy regarding the correct way to disassemble a rear axle.
You will need some basic and a few specialized tools to complete the job, paying particular attention to the bearing pre-load adjustments attained by using the thin banjo gaskets mentioned in the article.
Many differentials have been ruined by people with insufficient knowledge and the improper use of tools. Good Luck !
http://www.ocmafc.org/techarticles/T...0Re-Edited.pdf
Mikeinnj is offline   Reply With Quote
Old 05-12-2014, 11:56 AM   #10
jojofilo88
jojofilo88's Avatar
Thanks for the advice guys. In addition to your suggestions, I've been talking with the local Model A shop (A's and More) and he's helping me through it.
I couldn't get it off this weekend...Eric should be able to help me out of this bind...literally!
Joe
