05-08-2014, 12:33 PM | #1 |
Spark plug threads
I need to clean up the spark plug threads and I found a tap that is 7/8-18 NS.... Which i believe stands for national special. Is that the correct thread type? Thanks for your help in advance!
05-08-2014, 01:27 PM | #2 | |
Re: Spark plug threads
I've heard/own/used NF and NC, but not NS You are correct in doing your research where fords threads are concerned ! I'm aware of correct tools necessary to 'chase' threads, however , just any tool sold and claiming to do such job correctly..is not true..in most cases. If you 'chase'/ incorrectly 'clean up' plug threads and / or block threads..you've caused more head aches than you've cured. |
05-08-2014, 03:26 PM | #3 |
I just went down and checked mine and yours is correct. I believe NS stands for National Standard.
05-08-2014, 06:47 PM | #4 |
you don't want to use that tap,you need a thread chaser,it's a different animal,try Summit Racing.
05-08-2014, 07:53 PM | #5 |
are you attempting to use a spark plug that was not meant for a Model A ?how could the threads get damaged enough to have to recut or chase ? At 3 or 4 bucks a plug I would be chucking those plugs and buying new ones.
Wayne |
05-08-2014, 08:21 PM | #6 |
05-08-2014, 09:16 PM | #7 |
An old plug, with 3 or 4 grooves ground in it, makes a good thread "chaser"!----Bill W.
05-08-2014, 10:10 PM | #8 |
05-09-2014, 04:51 AM | #9 |
