04-21-2014, 03:39 PM | #1 |
another oil leak problem
Has anybody have oil spraying out the oil dip stick with the engine running? Mine is doing it at a fast idle and going down the road it gets worst. It is full to the F on the stick. Thought to remove the oil filler cap and it still does it. Its a rebuilt engine and there is no blow by. Any ideas, maybe lower the oil by say half a quart?
04-21-2014, 03:46 PM | #2 |
Re: another oil leak problem
Many of the oil filler pipes have had the baffles bent to allow oil to flow into the engine faster. Some are bent so that you can look straight through them. They will spray oil out when that is done. Bend them back to proper position or get a new/better pipe.
I noticed the harder I work the luckier I get! |
04-21-2014, 04:17 PM | #3 |
Here is a thread about the same issue. Turns out, the dipstick was the issue. Maybe the same with yours?
https://www.fordbarn.com/forum/showthread.php?t=133800
Ray White |
04-21-2014, 04:21 PM | #4 |
Ryan Scardina Livingston, Louisiana 1930 LSU Model A |
