Old 04-13-2014, 11:09 PM   #1
elwood
elwood's Avatar
Default Canadian heads..
Hey guys, my friend has a old set of Edelbrock heads and wants to grind the fins off and polish them to look like a set of Canadian aluminum heads.
Any thoughts ?
Will there be a cooling problem ?
Thanks ...
elwood is offline   Reply With Quote
Old 04-13-2014, 11:41 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Canadian heads..
Sure does sound like a lot of work... Reminds me of past projects of mine unfinished- too much work ...
Cooling won't be a problem...
Start with a mill.
Karl
Karl Wolf is offline   Reply With Quote
Old 04-14-2014, 01:29 AM   #3
scooder
I've got a pair of 81A aluminium heads here, I'd be happy to swap for a pair high compression finned edelhauser/Edmonds etc.
I really don't think you'd end up with something even resembling. Canadian heads with a grinder. Most finned heads are pretty much box shaped with fins if you at them from the side.
Martin.
scooder is offline   Reply With Quote
