Old 04-11-2014, 06:52 PM   #1
JSRTUDOR
JSRTUDOR's Avatar
Default Autolite 4100 stuck secondaries
Hi, I tried to rebuild my 4100 on my 58 Edsel and all was good except my secondaries were siezed. I soaked the piviot in PB Blast and was able to free them partially but by the next day they were siezed again. Anyone know a good cleaner I can soak the carb in to free it up permanently, or do I need to pull them out and replace it? Thanks!
JSRTUDOR is offline   Reply With Quote
Old 04-11-2014, 06:59 PM   #2
Ole Don
Ole Don's Avatar
Default Re: Autolite 4100 stuck secondaries
Don't give up so soon. Soak it overnight, wiggle it some, soak it overnight again, wiggle some, for as long as it takes. If it wiggled once, it will wiggle more after soaking with the right stuff, long enough. I once saved a rare AFB like this, it took weeks, but it ran good when it was cleaned up.
Ole Don is offline   Reply With Quote
Old 04-11-2014, 10:15 PM   #3
Alaska Jim
Alaska Jim's Avatar
Try a 50-50 mix of acetone and atf ( Automatic trans. fluid.) it works really well at loosening up seized parts. then follow Ole Don's advice. it may just take a little time and patience.
Alaska Jim is offline   Reply With Quote
Old 04-14-2014, 08:42 AM   #4
JSRTUDOR
JSRTUDOR's Avatar
Thanks!
