Old 04-03-2014, 02:29 PM   #1
HCO41
Default Shoe Box Oil Filter Gasket
I have two of the by-pass units I'm going to be using. One is held to engine via the head bolts ('49?), the other uses three 3/8-16 bolts that bolt to later heads with tapped holes.
While cleaning them up I noticed that the bolts, that hold the top on, have two different type gaskets. One has a mushed up fiber or plastic gasket, (orange), the other has a thin sheet metal gasket. My past experience has seen a copper gasket used on fasteners of this type. What is right or what has anyone used that works? Thanks,
Howard
HCO41 is offline   Reply With Quote
Old 04-03-2014, 03:33 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Shoe Box Oil Filter Gasket
All of the ones that I have use a hard fiber(paper) gasket on the center cover bolt. It really doesn't make much difference what material it is made of so long as it doesn't crush and it seals.
Old 05-23-2014, 12:57 PM   #3
HCO41
Since I first posted this thread I've gotten a '49-'53 Ford parts catalog. The PN for the gasket is 01A6749. I found a few sources on line but decided to call the local New Holland dealer since they have a past connection with the former Ford brand tractors. They still list the PN and were able to order a couple for me. Some of the larger or older dealers may stock them. Just to follow-up.
Howard
