03-30-2014, 08:09 AM | #1 |
Model A Roadster on the Lube Rack at the Pellissier Square Garage in 1931
The Pellissier Square Garage located at 828 South Western Avenue in Los Angeles was more that just a common gas station and repair shop. It offered the kind of service that is rare, if not unheard of today, but was not uncommon in big cities in 1931. The photo above is just one of four of this modern facility that include a Lincoln tow truck, the gas pump island and a good overall shot of the facility that can all be seen on The Old Motor. |
03-30-2014, 08:27 AM | #2 |
Re: Model A Roadster on the Lube Rack at the Pellissier Square Garage in 1931
What is the deal with the wheels on the roadster. They look like 17 or 18" wheels.
03-30-2014, 08:35 AM | #3 |
and the fenders and horn are not black. A standard top?
03-30-2014, 08:41 AM | #4 |
owner not a purest!
03-30-2014, 08:44 AM | #5 | |
03-30-2014, 08:46 AM | #6 |
03-30-2014, 08:50 AM | #7 |
I think it's a 1930 standard dressed up with a later shell
03-30-2014, 09:40 AM | #8 |
He's really shootin' the juice to the distributor.
Check out the camber on the car to the right. |
03-30-2014, 01:02 PM | #9 |
03-30-2014, 07:28 PM | #10 |
He, also has a stainless band on the spare tire.
MIKE (mikeburch) |
03-30-2014, 08:44 PM | #11 |
Great photo, Thanks for sharing it with all of us.
Henry's 31 |
03-30-2014, 09:07 PM | #12 |
I don't think the car on the right is a ford
03-31-2014, 07:59 AM | #13 |
I think the "A" roadster has a stone guard on the front of the radiator shell. If you look at it hard enough you can just barely make out a mesh
pattern. With maybe some clamps on the headlight bar that were used for the stone guard mounting?!? The car on the right up on the rack might be a '26/'27 Cadillac? Bob-A |
03-31-2014, 11:32 AM | #14 |
What is the guy greasing anyway ?
It must be the exhaust manifold bearing. ????? Me thinks it is staged just to show the attendent. MIKE (mikeburch) |
03-31-2014, 11:54 AM | #15 |
I was thinking the same thing, and that's why I made the comment about shootin the juice to the distributor. I guess if the grease gun has a long hose on it, then he might be greasing the water pump.
03-31-2014, 12:48 PM | #16 |
03-31-2014, 04:32 PM | #17 |
are they using an electrolux to suck out the oil? Look at the hose and pipes
04-01-2014, 12:19 AM | #18 | |
