Old 03-25-2014, 08:50 PM   #1
Russ/40
Russ/40's Avatar
Default How would you repair this?
Apparently on an earlier fender repair, this edge was ground so thin that it cracked. How would this be best repaired? I'm sure there will be different opinions, and I'd like to hear them all.
Russ/40 is offline   Reply With Quote
Old 03-25-2014, 09:54 PM   #2
tbirdtbird
Default Re: How would you repair this?
TIG would be sweet
'31 180A
tbirdtbird is offline   Reply With Quote
Old 03-25-2014, 10:06 PM   #3
ford3
remove that piece allowing an inch or so above and beyond it cracked piece, then stich weld in another piece from a donor fender, i dont think you can weld on that fender because it was ground so thin that it cracked, its very hard to weld on very thin metal with out burning holes at the thin place
ford3 is offline   Reply With Quote
Old 03-25-2014, 11:08 PM   #4
MikeK
MikeK's Avatar
I'll probably catch hell for suggesting this, but I would use AWS Bag-23 Silver-Manganese brazing alloy. It is 85%Ag, 15%Mn.
Tight solidus/liquidus range starting about 1780F, very fluid at 1900F, it will easily wet and flow into the cracked section leaving a very small fillet. Much stronger than the steel when finished, and ductile enough to take some dolly work to make corrections after.
It contains NO copper, zinc, or cadmium, so the problems known to using standard yellow brazing alloys under paint are non-existent.
MikeK is offline   Reply With Quote
Old 03-25-2014, 11:11 PM   #5
John Duden
John Duden's Avatar
I had something similar happen. I cut a section out of a donor fender and tack welded it in place. I then used a copper strip and welded/ melted it together slowly so it would not warp. then ground it all back down. For the wire inside I could not repair it so I took a piece of metal about 1/2 wide and about 1/8 think and bent it in the vice to the curve of the fender. Then layed inside of the bead and welded it. Now it does not have the weak spot where the fender usually cracks and bends
John
John Duden is offline   Reply With Quote
Old 03-26-2014, 07:44 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
This is how I would repair it,
Repairs the beaded portion of the fender. Has wire installed as original.
Old 03-26-2014, 10:02 AM   #7
d.j. moordigian
d.j. moordigian's Avatar
Maybe I'm not looking at this correctly,......
Is this the inside or outside of the fender?
Were is the reveal, the little 3/4" doodad above the bead?
d.j. moordigian is offline   Reply With Quote
Old 03-26-2014, 11:22 AM   #8
Russ/40
Russ/40's Avatar
This is the front of the fender, just inside the longitudinal crease. The involved area is small enough to make me hesitant to upset any sheet metal, and the inner wire is fully intact. This is otherwise a very sound fender.
Old 03-26-2014, 12:46 PM   #9
Seth Swoboda
Seth Swoboda's Avatar
TIG weld it.
Seth Swoboda is offline   Reply With Quote
Old 03-26-2014, 12:56 PM   #10
d.j. moordigian
Yep,.....I agree, TIG...
Old 03-26-2014, 01:09 PM   #11
28ACoupe
28ACoupe's Avatar
I concur, Tig weld that puppy.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 03-27-2014, 01:03 PM   #12
Russ/40
Russ/40's Avatar
Mike can you source that for me? I would TIG it if I had one, but don't.
Old 03-27-2014, 01:27 PM   #13
Fred K-OR
Fred K-OR's Avatar
I think my fix would be similar to Mike's or maybe it is the same because I don't know that much about selection of rods. If you don't have TIG, which I don't either, I would just braze it with a torch. Brazing is a lower temp than most welding and should not cause any distortion of the fender.
But my rigs are drivers and not show cars. So it depends on what you need to have.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 03-27-2014, 03:18 PM   #14
tbirdtbird
just remember once brazed it can never be welded....unless every spec of braze is ground off
'31 180A
Old 03-27-2014, 04:24 PM   #15
Fred K-OR
Fred K-OR's Avatar
Good point. Like I always say, I am not an expert on this type of thing.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 03-27-2014, 05:25 PM   #16
MikeK
MikeK's Avatar
Russ, I have ordered it from two different welding suppliers in the past. It was 1/16" stiff wire from Handy & Harmon. The 85Ag/15Mn stuff I used is also known as Silvaloy 852, Silvaloy, Z85M, Braze 852, and BAg-23. I'm sure there are other high silver, high fluidity braze alloys that you could use. Just avoid cadmium and zinc bearing alloys if you want to paint over it. I mentioned this stuff because it is very fluid and would fill your crack without messing up the crimp serrations on the bead- if your skill level is up to it. Last time I bought some was almost 4 years ago, and it wasn't cheap then, about $50 for an ounce.
Old 03-27-2014, 05:34 PM   #17
Russ/40
Russ/40's Avatar
Thank You Mike!
Old 03-27-2014, 06:06 PM   #18
d.j. moordigian
Mike,...are you using "Stay-Silv"? Russ, I would think, should know
this information...
Dudley
Old 03-27-2014, 09:54 PM   #19
MikeK
MikeK's Avatar
Originally Posted by d.j. moordigian View Post
Mike,...are you using "Stay-Silv"? Russ, I would think, should know this information... Dudley
Dudley, The Stay-Silv series of alloys from Harris are all phos/copper variants primarily for joining copper and brass (HVAC). I've used most of them over the years, but they are not for steel.
Harris does have one readily available alloy from it's array of Silver based products, Safety-Silv 56 that specifically is for steel-steel joints and has very high fluidity. I've used it to put broken-off mounting feet back on 10 Hp 3 phase reefer compressors. If it holds there, a fender bead is no problem. It too will work to penetrate the fender bead crack shown by Russ without overfill into the serrations, but with caveats: The alloy is Cu22%, Zn17%, Sn5%, Ag56% It does contain zinc, and will produce white dust (ZnO).
The moderate temperature for Safety-Silv 56, ~1200F is less than the self-clean temp for steel and will require a borax type flux. With the zinc fume dust and borate residue this alloy, also known as BAg-7, will require careful cleaning and light abrasive blasting followed by an epoxy primer to ensure long-term paint integrity.
The BAg-23 alloy that I initially mentioned will not have the zinc problem, and at 1900F will completely reduce any flux, if used, to inert glass and will do fine with abrasive cleanup followed by any primer or filler.
It was because of my perceived need to preserve the bead crimp serrations and integrity of the single bead wire that I did not jump on the TIG bandwagon for this particular situation. If it were a stress crack elsewhere I'd either TIG or gas weld it.
Of course, I'm no expert. I've seen guys who could TIG the lid back on a can of beans and it would look like it never saw the can opener.
