#1 |
Hi need some help what years do i need to look for a v8 clutch set up I have many 10inch for later Flatheads but don't i need smaller thanks Allen
#2 |
If you're running something like a 39 transmission use the Model A clutch and use the V8 pressure plate. That's what I did and it works fine.
#3 |
#4 |
There is a 9" version that looks the same as the later 10 inch with the flyweights on the levers --there is another 9" PP that is without the flyweights that is used on tractors and sold as a "replacement"---it will take the same heavy foot as the original A PP , the 9" V8 disc is the same as the A
#5 |
Speaking of clutches, a couple weeks ago I drove a 1949 Chevy pickup. You talk about a soft clutch!!! It was like there was no pressure plate at all, yet it didn't slip a bit. For someone that wants an easy clutch pedal, that's the one to adapt to the Model A.
#6 |
It has low effort pedal,works with throw out bearing.Really good clutch. Joe Way used a LUK brand Number 0029. Looked interesting |
#7 |
1946-1948 Long style clutch is what you are looking for. 9 inch. Has flyweights to add pressure at speed. Avoid the Ford tractor clutch without the flyweights.
#8 |
Ask for a 1940 Ford PP, you can also use a tractor clutch, available new but I don't think they have the weighted fingers, important if the engine has added horsepower. Consider a diaphram clutch, as John in IL suggested.
