#1 |
I'm putting sixteen inch wheels on for touring and would like some suggestions as to make and size for a tudor. Blackwalls only!
#2 |
Tires that is! It's tough getting old!
#3 |
lucas tire in CA,Lesters 16" Bias-Ply $147.00ea.
www.whidbeymodelaclub.com |
#4 |
I know I've said this many times, but 16" wheels and tires will make your Model A look funny.
#5 |
Youll going slower aengine rpm make engine work harder go luck withehver you do.
#6 | |
Only to you and the purists. To many of us, 16's fill the fenders better and look more up to date than the skinny A's.
Respecting and Resurrecting Ford Model A's. |
#7 | |
![]() Quote:
not really, I have 16s and the total diameter with tire is less than half an inch less than the 19s
1931 Slant Windshield fordor |
#8 |
I ran 16's for years on a Coupe and Pick Up. They cornered better than 19's and I liked the Look. I think the size was 16x 600. I have also seen 16 x 6:50's on the rears.
#9 |
i recommend radials. i run P-215-70-16
#10 |
I am running Dunlop Grantrek 215-70 R16 Radials on mine and am very happy with them. I am running them tubless and have had no problems with them. They are slightly smaller in diameter than the originals so the speedometer reads slightly higher.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
#11 |
If you have a fender mounted spare you might consider a slightly smaller tire for the spare to make for a better fit in the well. Sort of a first step towards todays "donut" spare tires.
Charlie Stephens |
#12 |
Hey Bill,
I'm with Jim B and second his recommendation for radials. But, Coker steel belt radials is what I use now ! Some GOOD things about these Coker radials for your consumption/consideration: Coker used an original mold pattern from the 1935 era...so the tire looks more correct with the rim. Coker makes a special heavy rubber 'radial' tube for their steel belt radial tire. Coker makes a tube 'stem protector' ...to protect the rubber stem which protrudes thru rim...otherwise will chaff /cut on the sharp rim stem hole ...VERY nice safety/custom touch for them to make for us ![]() I got white walls, which Coker gives you chose of widths of whitewall. Or you can get same tire in blackwall. Now back to Jims recommendation, regarding steel belted tires. I have run my Cokers for 8 years and they still look great, like new ! But, best assets of all, IMO, is that they provide a GREAT handling, ride and SAFETY at all speeds....which equals piece of mind , regarding being on the road and having no worries on where am I going to get the skinny original tires if emergency developes. Sixteen inch tires are commonly available for 16 in rims,eh! My experience/opinion only. I'm sure that you will get others. |
#13 |
If you plan on doing any serious touring 16 are the way to go. Cooper P215-70 R16 on my 31 SW with O D .
#14 |
Thanks all.The radials will be for touring and I'll keep the 19's for whatever. I have a Mitchell O.D. and "B" engine/w 5.9 head so I don't think the shorter 16's will have much effect on engine speed. Probably go with Cooper for pricing. Thanks again guys!
#15 |
I have the 215-70 r16 on my s/w and they ride great. And look great. I run them tubeless on 1935 wire wheel"s.
#16 |
There were a LOT of 16 on the MAFCA tour last week.
