Old 03-20-2014, 06:57 PM   #1
Flop
Default Early 1930 Coupe Restoration !
well ive had this one going for a while but havent gotten around to posting it .
she was a bad car to start with but Dave has had the car for about 40 years but his business took off .
so now its here for a full resto !!
shes pretty rough
new subrails getting fit
all smoothed out
heater hole
quarter patch i made up
subframe extensions out
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 03-20-2014, 09:23 PM   #2
Flop
Default Re: Early 1930 Coupe Restoration !
lower bracket for the rumble seat that mounts to the rubrails
first one i ever had to split!
some rust inside needed repaired . spot blasted repaired and put it in epoxy primer . then bolted her all back together
412 867 1659
[email protected]
Old 03-20-2014, 09:56 PM   #3
Vanspeed
Vanspeed's Avatar
Man you are good! How do you get so many "A" customers?
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 03-20-2014, 10:00 PM   #4
zzlegend
zzlegend's Avatar
Excellent Flop. Looking to see more on this one as you continue. Your an inspiration to others. Mark.
zzlegend is offline   Reply With Quote
Old 04-27-2014, 07:17 PM   #5
Flop
thanks zz !!
i did one car and it took off van .
door skin step 1
before welding
drivers side !
made up some cowl beads for the rot out
wheel well
nexxxxt !
412 867 1659
[email protected]
Old 04-27-2014, 07:22 PM   #6
Flop
door and cowl patches in !!
whole new pass bottom
handmade corner
the car is pretty much tied up . its at the blaster now !! should be back soon to put the floor in the start fitting fenders boards etc !!
412 867 1659
[email protected]
Old 04-27-2014, 08:01 PM   #7
bobpo1
bobpo1's Avatar
You know what you're doing as is exhibited in the photos. And it always stands true, "If you're going to do it, Do it right". I think you've got that part down to a "T" (pardon the pun, referring to an older model) .
bobpo1 is offline   Reply With Quote
Old 04-27-2014, 08:06 PM   #8
neds29
Flop- You make it look so easy! I love reading about your projects and looking at the pictures. I don't think there's any car you couldn't save, no matter how bad it was.
Keep up the good work.
Ned
Retired civil engineer.
Winters in Phoenix, summers in Ipswich, Mass. and North Dakota.
'29 closed cab pickup- Excellent AZ truck.
'29 roadster- Owned for 21 years but now sold.
'28 CC pickup- My first car in Andover, MA back in '62- '63.
neds29 is offline   Reply With Quote
Old 04-27-2014, 08:57 PM   #9
fordf1trucknut
Beautiful work as usual !!!!!
fordf1trucknut is offline   Reply With Quote
Old 04-28-2014, 10:26 AM   #10
todd3131
todd3131's Avatar
Flop, love to see your work, where else do you post?
Todd
todd3131 is offline   Reply With Quote
