Old 03-14-2014, 01:02 PM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default Wipers, vacuum
I'm not sure if this is a proper match, can anyone tell me what I should have and how I can put them together. Is it ok to bend the ears to get it together, and is it ok to have all that slop from side to side. Here is a photo of what I purchased from Snyders, Attachment 169660
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
Old 03-14-2014, 08:51 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Wipers, vacuum
Some slop is part of the system, less chance of it chattering if the blade can rock back and forth some as it sweeps compared to if it is held rigid 90 degrees to the glass --
Old 03-14-2014, 09:31 PM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
to put them together, hold the arm right side up and the blade upside down, with the open end of the clip on the blade facing the arm. Slip the clip over the end of the arm and into the slot, rotate the blade over so its now upright. Voila!
pat in Santa Cruz is offline   Reply With Quote
Old 03-15-2014, 08:06 PM   #4
Tom Cavallaro
Thanks so much...got it and it works fine thanks to all
