Old 03-07-2014, 09:24 PM   #1
52merc
52merc's Avatar
Default over drive solenoids
anyone used 1 of the new Chinese o/d solenoids?? I have 1 it works on bench test but on the car nothing so put my old 1 back on perfect ????
trev,, whats life "TOUGH" whats tough ' LIFE"
52merc is offline   Reply With Quote
Old 03-07-2014, 09:59 PM   #2
Drbrown
Drbrown's Avatar
Default Re: over drive solenoids
You may have seen this before but thought I try sending attached to you regarding repairing OD solenoids. Dan
Drbrown is offline   Reply With Quote
Old 03-07-2014, 10:07 PM   #3
Drbrown
Drbrown's Avatar
B-W Use Tips.pdf had trouble sticking on attachment. Dan
Old 03-07-2014, 10:26 PM   #4
52merc
52merc's Avatar
thanks for that dr brown what I cannot figure out is why this new 1 wont work in the car I did notice that the coil spring is not as heavy as old o/ds it test bench works but wont in car this is crazy
Old 03-08-2014, 12:07 AM   #5
Drbrown
Drbrown's Avatar
I was once told that a common problem is that the OD is not grounded - i.e. run a gnd wire to frame. Regardless, I expect this old-timer OD builder in Ohio can help .... gather as much info you can before you phone.
Lloyd Young, 614-837-7440 or 614-837-7832
Old 03-08-2014, 12:14 AM   #6
52merc
52merc's Avatar
thanks for that I might just try a ground to the frame to see whats what trev nz
Old 03-08-2014, 10:27 AM   #7
Kahuna
Kahuna's Avatar
Trev
I think the one that works is the one I sent to you some 10 years ago. If so, the warranty is OVER. ha ha ha
Jim
Kahuna is offline   Reply With Quote
Old 03-08-2014, 02:31 PM   #8
52merc
52merc's Avatar
jim you made my day mate!!! 8.30 sunday morning here and you gave me a great laugh you aint got another I suppose with a longer gaurente ??
lol yes mate it has worked well its like my body overworked and in need of a real good tune up,,,hows the car coming on regards trev
Old 03-08-2014, 05:56 PM   #9
52merc
52merc's Avatar
btt
Old 03-09-2014, 12:22 AM   #10
Kahuna
Kahuna's Avatar
Just having a bit of fun with you, Trev. Car's coming along
Cheers
Jim
