03-04-2014, 09:57 AM | #1 |
Balky A-block
I'm have an A block engine for my '30 coupe that I can't get started. I bought it rebuilt and low mileage. I got it from a friend so I know it ran at one time. I have installed all new ignition and a rebuilt carb. I have set all spark gaps, timing and carb adjustments according to the Mechanics Handbook (several times). I am using fresh gas. I have compression (using the time honored hand over the plug hole method). There is spark right down to the plug electrode. I have tried various adjustments to the spark advance.
The doggone thing won't even spit out a smoke ring... Any suggestions will be greatly appreciated. Thank you, Terry |
03-04-2014, 10:01 AM | #2 |
Re: Balky A-block
Do you actually have fuel getting to the plugs? Do you have the petcock valve turned on so the fuel can get to the carb? Did you rebuild the carb or at least make sure the jets are clear?
You might try putting 4-5 drops of fuel in each plug hole directly and see if you can get it to cough. If you have air, fuel, and spark, something interesting should happen.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
03-04-2014, 10:23 AM | #3 | |
Re: Balky A-block
If you have a good blue spark at the plug, I would check the timing. Are you sure the valve timing is right. |
03-04-2014, 12:06 PM | #4 |
Re: Balky A-block
Recheck your timing. When the pin drops into the cam gear detent the distributor rotor must be in this position. When books say to have the rotor pointing "OPPOSITE" number one, it means "NEXT TO".
All freeplay must be on the leading side of the rotor, which turns CCW. In other words you may be able to move the rotor CCW a small amount, but not clockwise. |
03-04-2014, 12:17 PM | #5 |
Re: Balky A-block
One of the best diagnostic "tools" is a can of starting fluid. If she starts on Starting fluid, it's a fuel, problem. If not, it's a spark problem. Unless it's both, but you should be able to sort that out.
Terry |
03-04-2014, 12:52 PM | #6 |
Re: Balky A-block
03-04-2014, 04:15 PM | #7 |
Re: Balky A-block
Yes he has spark, but if it is not blue it will not run. A plug can fire out of the cylinder, but might not under compression.
03-11-2014, 02:37 PM | #8 |
Re: Balky A-block
Thank you for the info. Using your suggestions and some other info from this forum I found out that the surfaces on the intake and exhaust manifolds were not level. I then remembered that I replaced the exhaust manifold about 10 years ago but cannot remember if the engine ever ran after that. So,,,,, I'm off to the machine shop to get manifolds "leveled".
Thanks again, Terry |
03-11-2014, 02:53 PM | #9 |
Re: Balky A-block
Welcome to the Barn, nice job of diagnosis. You must have had a significant leak at the intake manifold. Post some pictures when you can.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
03-11-2014, 04:09 PM | #10 | |
Re: Balky A-block
this is an easy trick to get pushmowers to keep running for the ones you prime pull start run for about 4 seconds then die. as its dying cover intake and it will suck fuel thru whatever may be blocking it.
1929 Model AA - Need long splash aprons! |
03-11-2014, 04:42 PM | #11 |
Re: Balky A-block
Is the battery fully charged?
