Old 02-27-2014, 04:31 PM   #1
Hioridge
Default RHD Shortened Pitman arm
Does anyone know if the shortened pitman arm such as part number A3590S from Tam's will work on a right hand drive Model A?
Hioridge is offline   Reply With Quote
Old 02-27-2014, 06:53 PM   #2
Juggler
Juggler's Avatar
Default Re: RHD Shortened Pitman arm
Pitman arms are handed. If you lay them flat on a their back with the ball upright, the one that twists to the right is lhd, one that twists to the left is rhd.
I'm not aware of any vendor that sells a shortened rhd pitman arm. You could however, at your own risk, heat and twist a lhd arm to fit. My buddy has done it and I plan to do one soon.
Regards
Juggs
Juggler is offline   Reply With Quote
Old 02-27-2014, 08:10 PM   #3
Logan
Logan's Avatar
I can't remember forsure, but I think maybe on my rhd speedster I couldn't get the pitman arm seperAted from the draglink, and I didn't have a lot of time to mess around with it. And I think I took a lhd pitman arm and drag link and used them. But I put the pitman arm ball facing outward instead of inward. And this allowed me to effectively steer it. Seems to work just fine for me.
Cowtown A's
Logan is offline   Reply With Quote
