Old 02-26-2014, 01:44 PM   #1
sanborn
sanborn's Avatar
Default Spark Plug Heat Range Question
We are finally getting to assembling the flathead engine. What spark plug plug should I use? The heads take a 3/4" plug, 14MM, the compression ratio will be 9.35 to 1.
sanborn is offline   Reply With Quote
Old 02-27-2014, 08:47 AM   #2
flat-v8
flat-v8's Avatar
Default Re: Spark Plug Heat Range Question
I have Autolite 437 in mine, it is a little hotter plug than standard 216
flat-v8 is offline   Reply With Quote
Old 02-27-2014, 03:45 PM   #3
sanborn
sanborn's Avatar
Thanks! At least I have a starting point.
