Old 02-22-2014, 04:02 PM   #1
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
Default Help storing a bare block
I just got my engine back from the family of my machinist friend who unexpectedly died a couple years ago. I'll need to "pickle" the newly bored bare block and crank and would appreciate some guidance as to what to use. Just grease up the cylinders and crank surface's with lube or bearing grease or is there a special application for an extended nap? Things start to rust quickly in South Fla. Thanks for any tips.
Rusty Homestead Fl is offline   Reply With Quote
Old 02-22-2014, 04:04 PM   #2
BlueSunoco
Default Re: Help storing a bare block
Rusty, I'd say probably cosmoline or something along that line. U.S. Military can't be all wrong in using the stuff. Maybe they have something better now, but years ago that was the best. You could store rifles for years swabbed down with the stuff.
BlueSunoco is offline   Reply With Quote
Old 02-22-2014, 04:16 PM   #3
tudoor
I have used this product on many things. Great for anything metal.
http://www.petroleumservicecompany.com/fluid-film.html
tudoor is offline   Reply With Quote
Old 02-22-2014, 04:39 PM   #4
Russ/40
Russ/40's Avatar
I checked the above out, and it looks ideal. Very much like what I have been using. For lack of knowing anything similar, I have used the motorcycle chain lube for long term solutions. The above seems similar in that it is a substance with wax that gels and stays where you put it.
Russ/40 is offline   Reply With Quote
Old 02-22-2014, 04:49 PM   #5
1930artdeco
1930artdeco's Avatar
I just greased the living heck out of mine and put in the garage. Every cylinder and bearing surface got greased.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-22-2014, 05:02 PM   #6
Will Ziegler in LI NY
Will Ziegler in LI NY's Avatar
I've used LPS 3, it's a spray on waxy type of coating that has stood up for years. I have a crank I sprayed 15 years ago and it's still rust free.
Will Ziegler in LI NY is offline   Reply With Quote
Old 02-22-2014, 05:06 PM   #7
Hicktick
Hicktick's Avatar
Get a thick , heavy plastic bag to put it in , after you bathe it in oil .
That's how engine builders do it .
Hicktick is offline   Reply With Quote
Old 02-22-2014, 05:19 PM   #8
Hicktick
Hicktick's Avatar
Here is a bag , if you want one ,
http://www.jegs.com/i/JEGS+Performan...80039/10002/-1
Old 02-22-2014, 05:27 PM   #9
jm29henry
jm29henry's Avatar
can you put it in a place where moister is nor a problem even a basement would be better than a garage>?
jm29henry is offline   Reply With Quote
Old 02-22-2014, 06:52 PM   #10
old car guy
Used to build motors and when we had to put one in a sleep mode we bathe it down with grease and oil bag it in a good heavy duty plastic bag and put it. A sealable 55 gallon drum . Before we sat them inside the drum would cut some plywood and put in the bottom. Set the block inside and seal it up tight. Many sat for a long time , and when they came out they looked just like they did when we put them in there. . Might be over kill. But. No bugs dirt or trash and they did not get damaged from falling over or someone putting something on them.
old car guy
old car guy is offline   Reply With Quote
Old 02-22-2014, 08:25 PM   #11
Rusty Homestead Fl
Good tips all. Thanks! That fluid-film looks promising. Appreciate all the reply's. Rusty
Old 02-22-2014, 11:16 PM   #12
MikeK
MikeK's Avatar
A basement in Florida? Rare bird. I think they call them indoor swimming pools.
MikeK is offline   Reply With Quote
Old 02-23-2014, 12:37 AM   #13
aojo
Two years ago I started to build a 63 Corvette motor for a project that never happened. I sprayed the bare block with Gibbs and id have checked the condition of the block every couple of weeks since and there is no sign of rust. This product is amazing. Check them out. I think there site is gibbsbrand.com. I bought it through a member here or on the HAMB.
aojo is offline   Reply With Quote
Old 02-23-2014, 06:30 AM   #14
QGolden
QGolden's Avatar
This product may be of interest to you as well.
http://boeshield.com/
It was developed by Boeing to store Airplane parts. It is a wax based product as well. Sone of my customers in Mills isle it to store Gearboxes and similar products in un heated buildings.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 02-23-2014, 02:20 PM   #15
nhusa
nhusa's Avatar
I heard that the military proved that WD 40 was best for rust prevention. Even better than cosmoline
nhusa is offline   Reply With Quote
Old 02-23-2014, 02:31 PM   #16
hardtimes
hardtimes's Avatar
Hmm, maybe so, but I do not believe that I'd go that route...from my experience with WD-40.
Model A/B blocks are small. Wouldn't take much room to place such block in a fairly small barrel/container and fill with used oil that you drain from your equipment. Recycling, eh..which people tout as good
hardtimes is offline   Reply With Quote
Old 02-23-2014, 03:44 PM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
I would coat the machined surfaces with grease, like Mystik JT-6 high temp, then place the engine in a large plastic tub with a lid.
It would be nice to have some of those military hermetically sealed aluminum tubs, but I never see them come up for sale.
Old 02-23-2014, 05:34 PM   #18
eagle
eagle's Avatar
My Uncle who was a machinist always used LPS Rust Inhibitor. He liked it because it will dry so dust and ??? won't stick to it. Leaves a durable wax film on the metal that will not rust even in a corrosive environment. He is the one that also told me to use the same product in the bottom roll of modern cars. Up here in the rust belt that is a very bad place for rust to start and LPS Rust Inhibitor applied every couple years keeps that area new. It is not a penetrant or anything like that so won't have any effect on paint or even markings from a permanent marker. It is in an aerosol can so is very easy to apply to all surfaces.
eagle is offline   Reply With Quote
