Old 02-20-2014, 02:06 PM   #1
adavis
adavis's Avatar
Default interior wood treatment
I'm working on installing new top and body wood in my '31 coupe and I'm curious what the best practice is for treating the wood before final assembly. It looks like the original wood was brush painted black but would some sort of oil that will penetrate or a sealant be better? Im not worried about originality....I just want to preserve the wood as best as possible.
adavis is offline   Reply With Quote
Old 02-20-2014, 02:26 PM   #2
MikeK
MikeK's Avatar
Default Re: interior wood treatment
You'll probably get a million answers here! When I replaced some wood on my roadster I slobbered it with This Stuff. When I was a kid, my dad swore by creosote oil and my mother always swore at the smell. Of course I always got to apply it to the porch and mile of fence during my summer 'vacation'.
MikeK is offline   Reply With Quote
Old 02-20-2014, 04:38 PM   #3
adavis
adavis's Avatar
So did you use "this stuff" and then paint over it or just go with it alone? I'm curious about tung oil. I think it would penetrate really well but just want to make sure there's not some reason I SHOULDN'T use it.
Old 02-20-2014, 06:09 PM   #4
garyaodell
I replaced the wood in my coupe because it had rot in it, the new wood I preserved with Copper Green. It has a strong odor but it goes away in a few months.
garyaodell is offline   Reply With Quote
Old 02-20-2014, 07:01 PM   #5
Doug in NJ
Doug in NJ's Avatar
Wasn't that copper-based stuff banned or something? I got a similar product at Home Depot about 10 years ago, but I haven't seen it for sale in a long time.
BTW, they also used to sell Polyurethane spray paint, which I haven't seen in ages.
For the wood in my car, I used polyurethane varnish simply because I had some lying around. I was reluctant to use my copper-based preservative on something I would have to touch...
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 02-20-2014, 07:19 PM   #6
MikeK
MikeK's Avatar
Doug, Chromated Copper Arsenate (CCA) was banned as a wood preservative. It was because of the near 50% hexavalent chromium that CCA was banned, not the 1/3 arsenic oxide (As2O5) content that really killed termites and ants. The active copper in Woodlife Coppercote is copper naphthenate, highly effective against dry rot, and other molds & fungus.
Old 02-20-2014, 07:24 PM   #7
Pete
Mike's stuff is the best available these days, UNLESS, you have access to chemistry stuff, in which case get some crystalline pentachlorophenol and mix it with cleaning solvent or alcohol. Generously paint all surfaces to be treated with a brush. The smell is like Lysol and will go away in a day or two. The parts will never rot or be attacked by bugs. It is not corrosive to your hands other than the smell which will go away in a few days. Just don't drink any of the solution or get it in cuts or your eyes. In other words, when handling it, USE COMMON SENSE like everyone used to do before the EPA set in. Rubber gloves recommended.
The wood can be painted or stained afterward if need be.
Old 02-20-2014, 09:08 PM   #8
Skibb
Skibb's Avatar
Just finished installing the all of wood in a 1930 Briggs Sedan. Used flat black Rustoleum thinned with mineral spirits. Perhaps another product would have been better.
Skibb is offline   Reply With Quote
Old 02-20-2014, 11:49 PM   #9
Lee Mitch
I used the green "terminix" type stuff as well because it is good for dry-rot and bugs. After it dried I double coated it with a Marine varnish to do a little better at shedding water.
Lee Mitch is offline   Reply With Quote
Old 02-20-2014, 11:59 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
This is what I used as it has the look and feel (waxy) of the stuff on the hidden parts of the wood that were overlapped.
Old 02-21-2014, 12:01 AM   #11
'29wagon
linseed oil
'29wagon is offline   Reply With Quote
Old 02-21-2014, 12:09 AM   #12
wrndln
I have done the same thing as Skibb - thinned Rustoleum paint. It seemed to work OK and low cost.
Rusty Nelson
Old 02-21-2014, 08:53 AM   #13
Terry,NJ
Terry,NJ's Avatar
I would have preferred linseed oil or spar varnish but I wasn't about to pay what they get for it today. So I went with polyurethane (JUNK) but it won't see the sun which is very destructive to a poly. finish. 2 coats of the poly. and one coat of flat black wood paint and I'm done. But really! Do we actually need that much effort and material on this wood? Most of the wood that is being replaced is, at best, 83+ y.o. and was outside in the weather or holed up in a leaky barn. My Town Sedan was parked in a leaky barn where the leak was on the right side and that's where all the water damage is. I don't plan to keep it out in the weather and I have no leaky barns in which to park it and let it rot away. How much preservative does it really need?
Terry
Terry,NJ is offline   Reply With Quote
Old 02-21-2014, 09:24 AM   #14
Doug in NJ
Doug in NJ's Avatar
Thanks for the information. I went and checked the stuff I have, and it is the newer Copper Naphthenate formula.
Doug
Old 02-21-2014, 09:03 PM   #15
Drive Shaft Dave
I did the same as Rusty and Skibb.
Drive Shaft Dave is offline   Reply With Quote
Old 02-21-2014, 09:29 PM   #16
KGBnut
KGBnut's Avatar
You all are thinking this much more than I did. I just used polyurethane. Maybe I was wrong, but it was the first thing that came to mind. I coated all the parts and let them dry thoroughly before assembly.
I also used Gorilla Tape anywhere two pieces of wood came together, or where they met a piece of metal. It did a great job eliminating squeaks.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 02-21-2014, 09:38 PM   #17
CC29Pickup
I used the Ebony stain by Min Wax. Great coverage and dries very quick.
CC29Pickup is offline   Reply With Quote
Old 02-23-2014, 02:09 PM   #18
Dale G.
Dale G.'s Avatar
ADAVIS,
Contact Don Turley to forward my recipe for wood preservative as Ford made. You can make it up yourself.
Dale G. is offline   Reply With Quote
Old 02-23-2014, 07:48 PM   #19
adavis
adavis's Avatar
KGBnut......what kind of Gorilla Tape did you use? I've got friction tape from Ace Hardware but would like to find something with a little more adhesion. The cotton stuff that was behind the original wood doesn't seem like a good idea because it could hold moisture so I don't want to reinstall that material.
Old 02-24-2014, 12:49 AM   #20
Drive Shaft Dave
The cotton stuff that was behind my original wood did not seem to be a problem in my coupe, what I did was some thin felt material glued to the back side of the wood. The only rot i had was in the wood around the rear window. I think the felt would work better as an anti squeek and to work as an anti vibration solution. Just my 2 cents.
