Old 02-03-2014, 10:38 PM   #1
Timsalways
Timsalways's Avatar
Default Door alignment 1930 Tudor Model A
Hi, I been searching to find out how to align the doors on my 30 Tudor Model A. And this is what I came up with. I got a gap of around 3/8 inch at the bottom rear of both doors. Everything else is ok. When people would tell me "your doors open", I would reply "That's the way they made em back then", Till I seen close up a 1928 Model A. I realized I have a problem.
What I am going to is pull the bolts out for the cross member, then cut the cross member then push the sides of my body out to meet the doors. Then re-weld it then re-attach the bolts.
Any advice will be much appreciated, I might make a video and post on youtube while doing it, I got a vacation coming up in a week.
Timsalways is offline   Reply With Quote
Old 02-03-2014, 10:51 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Door alignment 1930 Tudor Model A
SOOOO,!!! You're gonna' "BUTCHER" IT, are you!! Get smart & wait for some CREDITABLE advice, or, are you just tryin' to "SHOCK" us? No worry, we're well INSULATED against FOOLISHNESS!!
Bill W. (OH! I see your little green light on, just waitin' for a reply!!)
"THE ASSISTANT GURU OF STUFF"
Old 02-03-2014, 11:00 PM   #3
Timsalways
Timsalways's Avatar
I guess I could live with it. You think Bill it is a bad idea? And yes I had those little rubber wedges out, replaced them with new ones.
Old 02-03-2014, 11:01 PM   #4
Timsalways
Timsalways's Avatar
It don't have to come out much
Old 02-03-2014, 11:10 PM   #5
Marco Tahtaras
Marco Tahtaras's Avatar
I don't see the problem as severe enough to compensate by cutting up the floor. And yes, my first reaction is a rougher choice of words.
Assuming it has nothing to do with the lower door rubbers, the typical cause for this on a Tudor is the steel roof bow that ties the quarters together right over the rear of the doors. A slight reduction in the arch will spread the quarters at the top. Unfortunately that is tough to address on a finished car.
Again, the issue seems very minor. It seems to me the doors could be twisted that little amount without causing any bind in the function of the windows.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 02-03-2014, 11:16 PM   #6
700rpm
700rpm's Avatar
If you cut it you will regret it. And so will the next owner. Twisting the door is a more plausible solution. Best to find the real cause of the misalignment, and fix that, rather than do some farmer fix on it.
Ray Horton, Portland, OR
Old 02-03-2014, 11:26 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I believe that the wood in the doors is bad/installed wrong.
Old 02-03-2014, 11:47 PM   #8
Timsalways
Timsalways's Avatar
I will look into that, meanwhile, I will not be cutting with out more research! or at all.....
Old 02-03-2014, 11:54 PM   #9
swo4rd
swo4rd's Avatar
wood in the door of a 1930 tudor sedan??????I don't think so…
you must mean in the door jamb?
never cut the body or frame to make things fit…study the problem completely and then make adjustments…I suspect Marco's observation is correct but the note on the rubber anti-squeak is also a problem. i found the passenger side door on one of my tudors had the hinges ever so slightly bent.
swo4rd is offline   Reply With Quote
Old 02-04-2014, 12:04 AM   #10
BILL WILLIAMSON
Tim, I was just being smart assed, The Dog was prompting me. Study it out, those doors can be tweeked/adjusted to fit well. If the door is low in the back, it will make it out from the body. As others have said, the doors are all STEEL. Just be glad you don't have some BIG mis-alignment problem, like when someone welds a 1/4 panel in KROOKED!!! (NO! NOT on Vermin, his parts are straight) Dis-regard the RED car, Buster T. pushed the wrong button!
Bill W.
Old 02-04-2014, 08:11 AM   #11
RB35
RB35's Avatar
How is the horizontal alignment, meaning, do all of the trim lines line up? Have you checked the vertical alignment of the hinges? All in a row? I'm piecing a '29 sport coupe together on new subrails. Was a field truck with a wooden box hanging out the trunk. My doors started out 3" out at the bottom and slowly finding things to straighten, including the 'b' pillars. Now down to about 1/2". Sometimes closing a block of wood in the lower hinge will nudge the corner in, but be real careful.
RB
RB35 is offline   Reply With Quote
Old 02-04-2014, 08:24 AM   #12
George Miller
George Miller's Avatar
First off I would leave it like it is.Its not that bad. But if you are going to do it twist the doors as Marco and others have said. If you are strong enough you can garb the top and bottom then twist it. I have done it before, but not on a finished car.
George Miller is offline   Reply With Quote
Old 02-05-2014, 07:19 PM   #13
bikejunk
Can you push on the door and close up the gap? are the hinges sprung (bouncy binding) preventing the door closing fully , again as someone mentioned its tough on a newly painted car.
bikejunk is offline   Reply With Quote
Old 02-05-2014, 07:33 PM   #14
Timsalways
Timsalways's Avatar
Yes, I can close the gap by pushing the bottom of the door with some or little effort. What now?.......I want to put a 2X4 at the latch area. What do you think? I'm open for suggestions. Remember, the top is fine, and all my line's are good.
Old 02-05-2014, 08:02 PM   #15
johnny
Go to the hard ware store and buy two turn buckles with rods ,the type used on wooden screen doors,take the trim panel off and then fasten one end of the rod at the rear lower corner the other to the upper front corner.Then tighten the turn buckle this will pull the rear lower corner in .You may have to get two rods ie 1/4 or 5/16 inch rods and weld a washer to the one end and then weld the other end to each end of the turn buckle after cutting the eyes off. .Position the turn buckle in an open area of in the door so the trim panel will fit on.
johnny is offline   Reply With Quote
Old 02-05-2014, 08:12 PM   #16
Timsalways
Timsalways's Avatar
hmmm, Johnny, sounds ok, what if I bend the door with a 2X4? that rhymes
Old 02-05-2014, 08:13 PM   #17
Marvin/TN
Send a message via AIM to Marvin/TN
Should be an easy fix, use a soft block at the top of the door, I.E. a rubber sanding block, push the bottom of the door toward the sill. Do it a little at a time and only push on the door bottom in an area that will not bend the door outer skin. I have aligned a lot stronger doors than a Model A door. I use to jack up modern cars so that I could grab the bottom of the rocker panel and put my knees against the bottom of the door and pull with my arms and push with my knees. May be hard to do that with a Model A.
Marvin/TN is offline   Reply With Quote
Old 02-05-2014, 08:21 PM   #18
Marvin/TN
Put the block at the top of the door, read above what I wrote. I have been in collision repair for about 44 years. Fixed a lot of twisted doors.
Old 02-05-2014, 08:26 PM   #19
Purdy Swoft
Purdy Swoft's Avatar
I would twist the door. It doesn't look bad and could probably be easily twisted by hand. The top is closing all the way too soon and keeping the bottom from closing all the way. The lower rubber bumpers could be part of the problem. I've had to put a twist in doors on new cars and trucks when I worked at GM dealerships to get good alignment. I didn't like making such adjustments with the owner present. Some just don't understand what is sometimes necessary. I would temporarily remove the lower rubber bumper, place my knee against the lower bead on the door while pulling slightly outward on the upper rear of the door window frame. It may take a few tries. If it goes to far one way you can reverse the action until the rear of the door matches the curve of the quarter panel. Then if necessary, trim the rubber bumper until it fits.
Old 02-05-2014, 08:58 PM   #20
Mitch//pa
I would twist also
Do it with the window down
