#1 |
I have a bunch of Model A ammeters. How can I test them before I try to use them?
#2 |
You could test them for response by just connecting a D cell battery across the terminals. Short term high current won't hurt the D battery much.
You could test them for accuracy by putting them in series with an ammeter of known accuracy, also in series with a variable resistor all fed by the D cell. Twiddle the pot to limit current to something within the meter range. You can even do a little arithmetic to find out what range of pot you need. Volts equals current times resistance, V=IR. (Ohms Law and V would be 1.5v as the ammeters both have negligible resistance.) Harbor Freight sells an el-cheapo digital meter which will measure up to 10 amps. Small money for these like $5 on sale. ![]() What you read on one meter you should read on the other. Hope this helps Joe K
Shudda kept the horse. |
#3 |
