Old 01-26-2014, 07:08 PM   #1
Fireman580
Fireman580's Avatar
Default Early 1928 Model A
How can you tell a early model a 1928 from a late 1928 model A? vin#is a341574.
Fireman580 is offline   Reply With Quote
Old 01-26-2014, 07:18 PM   #2
Steve Wastler
Steve Wastler's Avatar
Default Re: Early 1928 Model A
If memory serves correct the serial would be about sept 28 I think you could look it up at Pluck's web site in the sticky post at forum beginning.
Steve Wastler is offline   Reply With Quote
Old 01-26-2014, 07:51 PM   #3
James Rogers
James Rogers's Avatar
Parking brake lever will be on the left close to the door.
Old 01-26-2014, 08:03 PM   #4
Steve Plucker
Get a copy of the MARC/MAFCA Restoration Guidelines and Judging Standards and learn all about it.
Early is usually Jan.-April;
Mid is usually May-August;
Late is usually Sept.-December
Except for the 1927 Model A's which I think are considered Very Early 1928.
Pluck
Old 01-26-2014, 08:09 PM   #5
Fireman580
Fireman580's Avatar
Thanks for the info.
Old 01-27-2014, 12:11 PM   #6
Gary Karr
Gary Karr's Avatar
First of all, your Coupe is a Special Coupe, which would put it sometime after June of 1928.
Gary Karr is offline   Reply With Quote
Old 01-27-2014, 01:47 PM   #7
d.j. moordigian
d.j. moordigian's Avatar
It should be an August of 28. Is this the block number?
For that month,...the hood, radiator shell, front brake actuators
and the front fenders aren't correct......do you have more photos?
d.j. moordigian is offline   Reply With Quote
Old 01-27-2014, 02:09 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
The headlamp lenses are for the TWOLITE system, which came out in February 1929, and the horn is a JC Whitney aftermarket, just like the one that someone put on my 29 Tudor. All 28's had fluted lenses.
