Old 01-25-2014, 05:57 PM   #1
prsvf1
Location: Northern Minnesota - The Cancun of the North!
Default Oil Pan Issues Using an EAB Engine in a 1940 Pickuo
Hi,
I have a 1940 Ford pickup under construction at this time. I am going to use an EAB Flathead V8. I don't know if it's a 1952 or '53 engine, but it has narrow belt water pumps that I am going to change out for '48 - '52 truck pumps to solve the mounting issue.
However, this engine has a center sump pan on it & I am not sure if it will work in a 1940 pickup. I have seen the '49 - '53 engines with a rear sump style pan used in 1940 Ford cars & pickups. Does anyone know if there are steering clearance issues using a center sump pan?
prsvf1 is offline   Reply With Quote
Old 01-25-2014, 06:04 PM   #2
37fatfender
37fatfender's Avatar
Default Re: Oil Pan Issues Using an EAB Engine in a 1940 Pickuo
You are going to find a 49-51 Merc passenger oil pan (rear sump) and the pump pickup tube. I just went thru this on my 40 coupe. The truck pan with the big clean out did not work either.
37fatfender is offline   Reply With Quote
Old 01-25-2014, 06:19 PM   #3
prsvf1
Fortunately, for me I have a 49 -51 Merc passenger pan (rear sump) laying around from a motor that I tore down several years ago. However, I probably threw out the pickup tube as it was caked with oil/sludge. I will have to check & see if I still have it. If I don't have it are they still available to buy new or do I have to find a used one somewhere? Also, I think it sounds to me like I can use the existing oil pump & I just have to obtain the right pickup tube?
Old 01-25-2014, 09:12 PM   #4
4tford
4tford's Avatar
sent you a pm
4tford is offline   Reply With Quote
