#1 |
Are there 3 styles of flywheel housings and what month/year were the
changes made? This is what I came up with. # 1. start of production... # 1a. variation of #1 , with the same shape... #2. more rounded shape... #3 late w/ reinforcing at the lower bolt holes...31? Thanks, Dudley |
#2 |
![]() ![]() ![]() I know of at least 3 different flywheel covers due to changes in the reinforcing ribs on the inside. I asked about these a couple years ago, but never got an answer. I think the only answer will come from a visit to the "BENSON FORD RESEARCH CENTER" in Dearborn, next to the Henry Ford Museum. You'd have to look at the flywheel cover blueprint and note the dates of the changes made. |
#3 |
Tom,
I'm calling that a " 1a " on a UP TO June or July 29, nice tool for " sweeping " the housing(turning the crank), KR Wilson? Thanks |
#4 |
Yes, it's a K R Wilson tool that I found at a swap meet about 5 years ago. It sure is nice for turning the crank, checking flywheel flange runout and dialing in the cover.
#5 |
I am told that the revisions to the Judging Standards will address the changes.
#6 |
#7 |
Actually, IF any "five hole" type housings were ever produced that way then they are late 1928 or early 1929. The housing Tom shows was used approximately the first half of 1929.
http://www.abarnyard.com/ |
#8 |
I have one with the part number (about 1/2" tall) cast into the lower portion that faces the engine; I believe it is not the later ribbed style but it is on a car now.
#9 |
I have close to 40 flywheel hsgs and am yet to see any with all 5 holes drilled. Several with the bosses for the 2nd anf 4th holes. If anyone has one with all 5 holes drilled, PLEASE post a pic, as I am having a hard time beleiving any were actually produced. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! Last edited by Rowdy; 09-08-2010 at 12:30 PM. Reason: MORE info |
#10 | |
![]() Quote:
#11 |
Rod, I know where there is at least one at. I cannot take a picture of it at the moment because it is up at Bill Sturm's getting upholstery installed but it is in Richard Barsky's early Sport Coupe (1/4/28). It was in the car when it arrived here for a re-restoration, and I am guessing it is an original one as it has the matching inspection plate. Does that help?
#12 | |
![]() Quote:
this cover was on ebay recently ... looks to be in very good shape .. cannot attest to authenticity ... did not sell |
#13 |
1-1-28 Parts book shows 3 hole cover FWIW
#14 |
How about this....3 distinctive EXTERIOR shapes with variations in each type? Also,
Marco, didn't you say there was a 2 bolt cover in E-28 or VE-28? Is this going to be part of the revision for the JS? |
#15 |
I will take you word for it. Rod
#16 |
I think a number of those have been drilled since Doc wrote about them many years ago. Note the depressions in the two upper corners. Those were added approximately May 1928. That fits what I said above however. The five boss housings were introduced near the end of 1928.
#17 |
The two bolt cover and housing was at the very end of 1928. We still have not located an example.
#18 |
![]() ![]() ![]() ![]() ![]() Here are the only 3 styles of flywheel covers I have. Also note that some of the steel dust covers have clipped corners and some have a sharp corner. I have no information about why or when for this change. |
#19 | |
![]() Quote:
Marco, maybe so as I did not research it. It was on the car when I disassembled it. Maybe I should call Doc and see what the deal is and what he wrote. Where I guess I am confused is if the 5 boss housing did not come out until late 1928, why did Doc (or whomever) make the addition in the early 28 section of the Stds? Wouldn't the factory have needed 5 bosses for the 5 holes in the inspection cover? If they only made the housings with three holes, why bother putting the other two bosses in the pattern? What am I/we overlooking? . |
#20 | |
![]() Quote:
