#1 |
We live in the Peak District in the UK. I am currently getting the '29 Phaeton licensed as a taxi (cab) to do tours in the area for holiday visitors. It will be the first pre 1930 (vintage) car licensed for private hire in the UK. What recommendations do you have to prep the car? It has cast brake drums, I've bought the Flat Head Ted floaters. It has two rear lights but is on 6 volts.
#2 |
I'm sure the authorities in the UK already have a list of requirements. I'd start there first.
As far as others, IMHO an experienced professional Model-A mechanic should inspect all things mechanical and "sign-off" that everything is safe mechanically as this is not something you want to extend your liability to if you are not knowledgeable about Model-A mechanicals. |
#3 | |
![]() Quote:
Will you use the car year round, or will you park it during road salt season? ![]() |
#4 |
As a fellow UK Phaeton owner I can say the floater kit works very well giving good braking performance. I have stuck to the 6 volt system again without problems and I don't suppose you will be doing after dark excursions anyway which may show up any short comings. I have installed a water temperature gauge for peace of mind and a cut out switch as a safety precaution but apart from that have kept things standard with no obvious
problems arising. I think Henry got is basically right in the first place . Best of luck. John |
#5 |
Oil filter and air filter to get max use out of your engine since you are using it for business.
#6 |
#7 |
I bought an air filter but they don't fit a right hand drive car - steering column in the way. Is the oil filter really worth while?
#8 |
As far as the oil filter goes I am not sure you need it. If you have a full pressure system then yes. But if you have a stock engine then probably not. Remember if they can have taxis back in 28-31 w/o filters and they lasted on those dirty roads then on our clean roads it should be fine. The difference is you will have to change oil much more frequently w/o a filter.
That is my opinion. Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
#9 | |
![]() Quote:
It is good to hear they are making exceptions for you regarding necessary requirements to be a Taxi. Best of luck to you in your new business venture! Sounds exciting!! |
#10 |
I'm thinking seat belts, not so much for the front impact crash protection, but just to keep customers seated where they belong. Model A door latches can and do pop open if banged hard enough on the inside by an oversized, overenthusiastic tourist bum. There is no interlocking capture pin like modern latches.
#11 | |
![]() Quote:
Sounds like a fun way to tour on old roads to see the sights. Are you near Buxton?
Jim Cannon Former MAFCA Technical Director ![]() "Spread the Joy! Have a Model A day!" |
#12 |
I hope your in the British Model A Club mafcgb.org.uk
Might be worth Contacting John Buckley for advice . He's on the Barn and does a lot of miles all over Europe |
#13 |
I would get the grease point poster and have that done per schedule. Also read the owners manual for your year A.
http://www.motormayhem.net/model-a-f...owners-manual/
Wanted: Simmons Super Power Head ![]() Craig Likon 1931 150B |
#14 |
[QUOTE= "How best to connect a cigar lighter to the electrics for the gps?"
Not sure what you have availible in the UK, but several of the Model A supply houses here list an inverter for 6V Positive Ground to 12V Negetive Ground, 2.5 Amps. That should be more than enough power for a GPS unit. Or Google [COLOR=#006621]www.radiosforoldcars.com/power.htm You may also find a supplier in the UK.[/COLOR] On a safety note, I would consider installing the LED Stop/Tail lights. They show up much better that the incandescent bulbs. Good luck on your journey. Ed |
#15 |
I insulated the socket and hose clamped it to the steering column. This way you can run the center contact to + ground and run the outside to the starter switch or terminal box. 6 volts works my GPS just fine.
#16 |
Research the outer rear wheel bearings. Do not try to lube from the zerks. Probably best to annually pull the rear hubs and repack the bearings.
Seat belts for all occupants. Do you need a backup driver? Bob |
#17 | |
![]() Quote:
http://www.earlyfordparts.co.nz/right_hand_drive.htm |
#18 | |
![]() Quote:
2000 miles a month. change oil every 500 miles: 5 bucks per quart. 20 bucks per oil change. 80 bucks in oil a month. Oil change every week= your time($) Change oil every 3000 miles with oil filter change: 5 bucks per quart etc etc. There are some synthetic oils that claim 15000 mile oil changes. As for the air cleaner, the roads are cleaner. So why does everyone still have a air cleaner on their modern car? We even added air cleaners to our turbine engined Blackhawk helicopters when I was in Iraq. The engines lasted MUCH longer. Even those flying from hard-stand to hard-stand. My two cents..... Pot is now stirred. ![]() |
#19 | |
![]() Quote:
There was a post here not too long ago with a wonderful little power outlet to use on these cars. It is a fully insulated plastic shell (so not shorting out) with 2 wires coming out that you can connect however you need. Where you would connect the black wire to earth on a modern car, you can connect the red wire on the Model A. https://www.fordbarn.com/forum/showthread.php?t=116118 I bought one for my Dad to put in his car.
#20 |
This has been very useful. The argument for an oil filter is fairly convincing. Think I'll see how popular it is first before fitting. Like the idea of the led rear lights - will definitely fit. I won't be fitting the seat belts as it implies a level of safety that I can't prove and possible don't offer. The blurb will say no belts. Doors opening is not such a problem as you can't fall out. My gps also runs on 6v so a simple socket fixed to the steering column sounds good. The turn indicators are already fitted.
Anybody got any ideas on a suitable clock for the dash to keep me on time? The R&D air filters look like a nightmare. I'll just stay off the dusty roads;-) I am a member of the MAFCGB - John used to own my car. We are close to Buxton. I have five routes planned. The website should be up and running in the next couple of days - www.vintageadventuretours.co.uk It will be a great way to spend an afternoon, for that is. Paid to drive a Model A in the countryside. Can it get better? Might need some help on the driving though if it gets popular. Keep it coming |
