Old 09-06-2010, 04:53 PM   #1
RBaker
Default Help decode serial number
The 38 Ford truck serial number on my frame has a letter "I" as the last digit.
It looks exactly like this on the frame *18-464258I*
Would my serial number be 464258?
or
Would it be as the Vanpelt website list serial numbers such as 18-4, 64258I?
The "I" being a number 1 even though it is a definite letter "I"?
I was not reading the number correctly the last couple of months due to rust/dirt etc...
RBaker is offline   Reply With Quote
Old 09-06-2010, 05:08 PM   #2
John R
Default Re: Help decode serial number
The "I" stands for a 1 (one).
John R is offline   Reply With Quote
Old 09-06-2010, 05:09 PM   #3
Don Rogers
Don Rogers's Avatar
Your serial number is 18-4642581 and it indicates that the engine was built in August of 1938.
Don Rogers is offline   Reply With Quote
Old 09-06-2010, 05:23 PM   #4
RBaker
Thanks fellas the "I" had me confused a little.
Old 09-07-2010, 01:00 AM   #5
Milt/Las Vegas
Milt/Las Vegas's Avatar
How did you come up with the engine being built in aug.,38?
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
Old 09-07-2010, 03:48 PM   #6
Don Rogers
Don Rogers's Avatar
There are several sources for engine build numbers. I used DeAngelis book "The Early Ford V-8 Book" You can also get the information from The 1938-39 Ford Book published by The Early Ford V-8 Club.
Old 09-07-2010, 04:05 PM   #7
Kube
Kube's Avatar
Keep in mind that if an engine was built in August (example) it may very well have sat for a while before being installed in a vehicle.
In other words, an August engine does not necessarily mean an August vehicle.
Old 09-07-2010, 09:02 PM   #8
Lamar Wadsworth
Lamar Wadsworth's Avatar
The only info that can be gleaned from your serial number is that it has the 85 HP V8 engine (indicated by the 18- prefix; 60 HP vehicles had a 54- prefix), and the approximate month the engine was built. The number following the prefix is just a sequential production number for the engine/transmission unit. When the engine/ trans unit was bolted into a chassis, the number on the bellhousing was copied onto the frame rail. A higher numbered engine/trans may have gotten bolted into a chassis before a lower numbered engine/trans. There is no info about body style, etc. encoded in the serial number. 1/2 ton pickups and panels were built on the 112" wheelbase passenger car chassis and are in the same serial number series.
Lamar Wadsworth is offline   Reply With Quote
Old 09-09-2010, 09:54 AM   #9
RBaker
After removing my cab from the frame yesterday I found this......a circular date type stamp with the letter D followed by the numbers 37. Also the number 12 to the right of the date stamp.
Would this mean the block was cast in December 1937?
Also, when I had the heads and intake removed the aluminum intake had a date stamp of 11-16-37 underneath.
Old 09-09-2010, 01:03 PM   #10
southfork
southfork's Avatar
My 1/2 ton '34 Ford pickup has a BB prefix before the serial number on the frame. I guess that means it came originally with a 4 cylinder engine?
southfork is offline   Reply With Quote
Old 09-09-2010, 06:37 PM   #11
southfork
southfork's Avatar
Oops! I misspoke. The prefix to the serial number on my '34 pickup is "B I8-".
I have heard of some '34 Ford serial numbers starting with a "40" prefix (presumably be they are a Model 40). Anyone actually seen that prefix?
Old 09-10-2010, 08:31 PM   #12
Lamar Wadsworth
B prefix denotes 4 cylinder. BB prefix is big truck (or a pickup that was equipped with the granny gear 4 speed instead of the 3 speed passenger car trans that was in most pickups).
Old 04-05-2017, 06:38 PM   #13
bobmg53
I have a BB pickup with the 4 speed. Is 4th as high as 3rd would be in a three speed?
bobmg53 is offline   Reply With Quote
Old 04-05-2017, 08:58 PM   #14
Kube
Kube's Avatar
The forth gear was VERY low. Many called it the "Granny gear". Think of it a s a good gear for pulling tree stumps.
In a modern vehicle that first gear would rarely be used at all.
Old 04-05-2017, 09:10 PM   #15
deuce_roadster
deuce_roadster's Avatar
I think 4th is straight through just like 3rd is on a 3 speed. Are you calling 4th the lowest gear or the highest gear?
Old 04-05-2017, 09:16 PM   #16
cas3
i believe that was misunderstood, high gear, 4th gear in this case, unless an overdrive, is always 1-1 ratio, same in the three speed. big power and low highway speed is achieved by the rearend ratio.
cas3 is online now   Reply With Quote
