Old 01-10-2014, 08:53 PM   #1
Gavin
Default Drive shaft roller bearing shaft OD
I need to have my drive shaft bearing surface metal sprayed and turned down but am not sure of what size this should be. I understand the worn limit is 1.085". We have one shaft measuring 1.096" - is this the nominal size?
Cheers,
Gavin
Gavin is offline   Reply With Quote
Old 01-11-2014, 12:09 PM   #2
RonC
RonC's Avatar
Default Re: Drive shaft roller bearing shaft OD
Would it be better to just swap it out with another one? Also I would think the original surface would be harden the same as the spindle bearing surface. Will you be able to duplicate that?
RonC is offline   Reply With Quote
Old 01-11-2014, 12:22 PM   #3
jimvette59
jimvette59's Avatar
RonC there is a metal spray on process that can be applied that is hard. I used it 40 years ago.
it was sold by EutecticCastoline. I think that was the name of the Co. Not an easy prosess. JMHO
jimvette59 is offline   Reply With Quote
Old 01-11-2014, 12:28 PM   #4
RonC
RonC's Avatar
Jim, That's good to know. Any idea of cost ?
Old 01-11-2014, 03:03 PM   #5
Gavin
I have found the bearing surface pitted and unsuitable for the bearing to run on after the driveshaft has been modified to fit a Leycock overdrive. A pity I did not find this earlier. I can always use 1.096" but would prefer to have the original size confimed. Cheers,
Gavin
Old 01-11-2014, 03:27 PM   #6
Bob C
You might try sending Tom Endy a PM. I think he posted one time about
repairing this area.
Bob
Old 01-15-2014, 01:07 PM   #7
Gavin
Bob C,
Thanks for your suggestion but Tom Endy was unable to help. However, Tom Jordan of Snyders confirmed the 1.096" dimension which is much appreciated.
Cheers,
Gavin
Old 01-15-2014, 08:33 PM   #8
roddyb34
roddyb34's Avatar
Just a side question regarding this bearing ,,has anyone replaced this bearing with a series of say 3 ball type sealed bearings to replicate the same dimension of the original ,,i presume machining of the shaft and T,tube to accomadate the bearing would be difficult ,,
roddyb34 is offline   Reply With Quote
